190 Views 0 Replies Latest reply: Nov 21, 2012 9:04 AM by dtfee RSS
dtfee Just Startin' 1 posts since
Feb 20, 2012
Building MCU code in Codewarrior v10.2
Hi Folks,
This is my first post. I'm a UK based software engineer with an interest in music DSP so I thought I purchase this kit through a US based friend. So far it's been a really steep learning curve but I wanted to upload my experience of trying to build the MCU code (microcontroller only) on a PC running windows XP and see if anybody else had any tales of their experience they'd like to share. At the moment Freescale offer a special edition of Codewarrior for MCUs - v10.2. It's a bit ropey but after weeks of faffing about here's my instructions for getting the build to work:
1. Download and install Codewarrior 10.2 (special edition - free)
2. Create an empty workspace on the same drive as the installation, e.g. C:\ToneCore
3. Copy 'MCU sample code' to a directory under the workspace directory and rename MCU_sample_code. This avoids any problems with include paths.
4. Import the project following the instructions outlined here:
http://www.freescale.com/infocenter/index.jsp?topic=%2Fcom.freescale.doc.CodeWarriorProjectImporter.QuickStart%2Fdoc%2FProject_Importer_Guide.CodeWarrior_Development_Studio.html
where the MCP file is 'TCDDK User Template Rev 1.mcp'.
5. When you get to the 'Access Paths' part of the import, add an extra entry: {Compiler}\lib\HC08c\device and set 'Recursive' to true.
6. Click next, there should be only one entry: User_Template_Project.map. Else, search for the missing folders and go back to 5 to add the paths.
7. Continue to Finish, selecting the remaining defaul options.
8. At this stage, you can try a build - Project -> Clean... (selecting 'Start a build immediately'). You may be lucky and everything works fine.
9. If, like me, you weren't, right-click the project in Project Panel, select 'Edit Linked Resource Locations' and select 'Linked Resources' tab.
   Likely, you'll see a list of Invalid Locations. Click 'Path Variables' and edit CW_IMPORTER_ProjectDir, replacing ${PARENT_LOC} with the actual path.
10. At this stage, you may get as far as 'No rule to make target...' referring to a path containing virtual/virtual.
    Open Properties, select 'C/C++ Build -> Settings' and select 'S08 Linker -> Input'.
    Edit the Parameter File entry before 'MCU sample code\...' to your correct location.
11. Rerun the build. We now get a bunch of linker errors mostly referring to main.c and IO_Map_c.obj.
    This is because something called ProcessorExpert generates another copy of the same code.
    Under the 'User Modules', delete the TCDDK_User_Template_Rev_1.c file (or whatever generated file contains an empty main function) and
    under 'Generated Code' delete IO_Map.c.
12. Rerun the build. Hopefully this time it all worked and you have a nice new MCU_sample_code.abs.s19 file to download through the TCDDK GUI.
I'd be interested to hear from anyone who's found this useful.
Best wishes
DTFee
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
