Nov 30, 2012 1:01 PM
Odd and annoying sound
Like (0)
Hey All!
I have a POD HD500. There is a sound that is present in most of the models i'm concerned about. I've seen several dicussions about hiss and odd sounds, I figured I'd ask ya'll in case I'm missing something. It's sounds to me almost like clipping. Kind of like a crackle maybe- it's hard to describe, Unpleasant is probably the best description haha! I should start by mentioning I have used a POD XTLive for a few years with zero issues, along with both the Flextone II and III, so I think I have a pretty good grip on this gear.
I am playing mostly pop/dance/rock, so I'm not generally using heavy distortion.I generally run the POD using the 1/4" out into a Behringer B212A. The sound is there. When I record it into my Boss BR1600 it's there using the XLR outs. In 3 different pairs of headphones it's there. I'm not pushing into any of those units very hard, no clip lights are showing. I have am having this issue while using a Peavey HP Special, which I am aware has high output pickups. But it also is an issue with my Strat with single coils, and my Variax 600.
Using Meambobbos guide I tried a few things including turning down the volume on the guitar which doesn't help. I run the POD with most patches channel volume between 50-60%, and the Master at 50%. I never have the Drive maxed. The most useable sounds are the Uber for crunch/distortion, The Hiwatt, and now the Slo clean for clean. The Slo doesn't have this problem at all, so while I was thinking it is a defective unit, I'm not so sure now. I haven't tried the other new models so I can't comment there. A couple of the models like Gibtone, Divide, and PhD are unuseable, because the sound is so prevelant.
Some other relevant settings I'm using; Studio Direct, Guitar in Z -Auto (I have tried others with no luck). And though I've tried every combination of input selection, (I agree that using Guitar and Same do increase the volume, and possibly contribute to the issue), so I am globally set at 1-Guitar/Variax, and 2-Variax. The reason I do it this way is that the tuner doesn't seem to work on the Variax if you are set on 1-Guitar and 2-Variax.
So, that's the best description and relevant facts I can think of. Any idea what I may be missing? I've been using Line 6 gear exclusively since 2000 and this is the first time I've run into issues like this.
Thanks!
Phil
can you record it and send an example?
Thanks for replying jws1982, I knew I should have posted some examples. I just put a couple up on www.soundcloud/philschon . These are just a couple of strummed chords with 3 different guitars; Peavey HP Special, Strat, and Variax 600 on the Lester setting. The patches are the default amp models with no tweaks. It's enough to show the crackle sound. You can especially hear it right after the strum.
Some relevant settings are Studio/Direct, Input 1-Guitar/Variax, Input 2- Variax. Master at 50%. These are also Full amp mdels, not pre's. It is recorded straight into a Boss BR1600. There are no indications of clipping at the recorder. I get this sound at my Behringer monitor, and headphones. It's everywhere! Haha!
Check em out. Lemme know what you think Thanks!
I'll have to try it out on mine when I get home. Can you send an example of a completely clean patch, or is that last blackface patch supposed to be clean?
Ok. I added 2 more sounds. They are both lightly picked at first, so you can hear the clean. Then they are strummed. You ca really hear a definitive break-up at the beginning of the strums. This breakup (besides sounding nasty) sounds the same across almost all the models, so I don't think it's a typical crunch or breakup found in some amps.
http://www.soundcloud.com/philschon
Thanks for your help...and time
