499 Views 9 Replies Latest reply: Dec 27, 2012 6:26 PM by dgnyberg RSS
pcep Just Startin' 8 posts since
Dec 2, 2012
Dec 4, 2012 12:13 PM
New JTV-69 Day!
Hi everybody,
I just received my Korean JTV-69 (Black) yesterday. I had a little bit of time last night to sit down with it, through headphones (JTV-69 > M-Audio interface > Logic 9 with Amp Designer).
I'm usually more of a fixed-bridge kind of guy (my main guitar is an Gibson SG), but I went for the 69 for a few reasons. First, if I love this guitar then it will be replacing a Godin LGX3 (which is a Strat-style with an LR Baggs piezo bridge...no hex output, though). Second, I went for the 69 instead of the 59 because I felt the trem would be useful on some of the models (e.g. the Gretsch).
I currently play in a couple of bands. For the main band's bigger shows I haul out my SG, the Godin (as a backup, tuned with a capo, etc.), a Gretsch baritone, a Fender banjo, and a mandolin. That's a LOT of strings to haul around & keep in tune between sets! In addition, on our recordings I always use a variety of instruments: all of the above mentioned instruments, Telecaster, Rickenbacker, PRS, you get the idea.
For the other band I use a LOT of altered tunings, so I bring out 3 guitars just to handle quick changes between songs.
So, I figured I'd try one of the new Variaxes. I've been interested in the technology for a long time now, but the fact that the earlier Variaxes had no magnetic pickups was a deal breaker for me.
My first impressions: great so far. Out of the box the intonation is great. I didn't go over the finish with a fine-toothed comb or anything yet, but it seems fine to me. The neck feels great, and I have no problems with the frets or nut. To be honest, because I'm a pretty heavily gigging musician all my gear takes a beating. So, if there's a flaw in the paint/finish I don't get too concerned, because I know that it will be inevitable that the guitar will get knocked over, get something spilled on it, etc. at some point in the future.
So, physical quality seems great. Stays in tune, trem seems smooth (I read about people having issues with their trem "catching" or not returning to pitch...I haven't experienced that yet). I didn't have any problems with engaging/disengaging the model selector switch.
I played around a few hours with the different models. I'm loving some of the electric models. The chime mode through an AC30 model...instant vibe. Gretsch through a Bassman model with some spring reverb & slapback, immediately in the rockabilly world. The Tele models & semi models were great, as are the jazzbox models.
I also really liked the dobro models, and I think the banjo will be good enough in the band mix so that I'll be able to leave my banjo at home. If I were playing bluegrass that wouldn't be the case, but mixed in with a loud band I think it will be fine.
Through headphones I wasn't terribly impressed with the acoustic models. But, to be honest, I was still hearing the physical guitar under the acoustic models, so I wasn't getting an accurate representation.
I also found that all of the 12 string models were very artificial sounding. I'm hoping that by adjusting the volume & pitch of the octave strings in Workbench that I can get them sounding more realistic. Has anybody had any luck with that?
I have a rehearsal tonight, so I'm really looking forward to playing this thing through my real setup and hearing how it sounds in a live situation. I already have an A/B set up on my pedalboard (to accomodate the banjo & mandolin), so I'll also be able to check out the acoustic models through the PA tonight.
Overall, I'm really really happy with it so far. The variety of sounds is astounding, and the ability to switch back and forth between altered tunings is almost as good as having a roadie handing me a guitar between each song. If this thing is a keeper, then I'll go from having to bring out 2 guitars, 1 baritone guitar, banjo, mandolin, and one of those big 5-guitar stands to bringing out 2 guitars, a mandolin, and a small double guitar stand. I'll also save myself a lot of time in tuning all those instruments.
In addition, for a long time now I've wanted a big hollowbody, a 12 string, a Tele, and a dobro. I love having a big palette of sounds to choose from, to be able to best suit the song that we're playing. I haven't purchased all of these, though, because to be honest I wouldn't get a lot of use from them (except for the Tele)...I'd use them here and there. Now that problem seems to be solved.
I'll post my thoughts and experience after rehearsal tonight, too. That will be the deciding factor.
  • petef Just Startin' 28 posts since
    Oct 13, 2010
    Dec 4, 2012 1:55 PM (in response to pcep)
    Re: New JTV-69 Day!
    PCEP,
    Great deal!  Welcome to the JTV world, sounds like you got a good 69.
    Check a few things:
    Make sure the set screw for the tremelo arm is in there (i.e. not loose and going to fall on the floor...lost).
    Lube the tremelo pins (guitar grease or Chapstick), just need a bit.
    On acoustic models, they need to be played FRFR with a flat model (direct to PA)... though I'm sure you know that.
    What signal path are you using... saw the AC30 sim... don't know the path though..
    I use an HD500 (so power is not an issue for JTV).
    If you are going to get a DVI cable (for an HD500), you may want to consider one from Best-Tronics vs. the Line6 (too stiff).
        Dec 22, 2006
        Dec 5, 2012 9:08 AM (in response to pcep)
        Re: New JTV-69 Day!
        I've heard of some users adjusting the octave strings a little in workbench... to either add a little detune or remove a little detune to taste...
        i personally think the 12's are ok... certainly less headache to tune it up this way!
    • DrFunk Just Startin' 59 posts since
      Apr 25, 2007
      Dec 18, 2012 2:13 PM (in response to pcep)
      Re: New JTV-69 Day!
      Hi PCEP,
      I've been enjoying your thread. Very positive, really what the JTV is all  about. It's funny that most people are here to complain!  Anyway, I really like what you have to say and your criticisms are accurate. Alot of people have noticed artificial sounds with the 12 strings (frequently noticing artifacts in the harmonics). I think line 6 did a really thorough and good job on the models including the 12 electric and acoustic strings. May I suggest the solution is not to tinker in Workbench, but to adjust the JTV's string height just a tad higher. See if that does not improve the models. If you notice artifacts or strange harmonics just adjust it back to where you had it or slightly lower in height next. I think this will solve your problem,,,
      If the string height is right- ALL the models should sound good,,. In fact they should sound Great just like the instruments they are modelling,. Line 6 really nailed it.,, In a band mix or in a recording, very few discerning ears can even suspect that you are doing this with a modelling guitar!
      I don't think you'll have any problem with your pedals if you get an HD500. It has programmable EFX loops that you can put anywhere you like in the signal chain. So, Wah's, OD,distortions, Fuzz you can put before amps and Modulations, Delay and reverbs you could put after if you like and keep any of the pedals you want to continue using.  Line 6 has ~96 effects on board to choose from. many of them are excellent, ultra programmable, and may replace a few of your pedals. So even less to carry around. Sounds like you'll be bringing~ 3 less instruments with you already!  I love my Electro Harmonix Black Finger (tube compressor), the Radial Tonebone Classic (tube distortion), TC Chorus and the EH Deluxe Memory Man (Delay),... So I can keep them in my signal chain thru the EFX loops at will for any given preset, Oh yeah, and the Eventide Pitch Factor (harmonizer).
      I'm a strat guy, Not surprising that I have a few strats at home. I find the strat model that Line 6 chose sounds as good if not better than some of my Customshop strats! The sound is really good. I only miss the 'feeling' of the fretboard/ neck on some of them- that's what I notice but the sound is terrific. they nailed a perfect stratocaster!
      Good luck with your JTV69, the band and in your recording. Lots of JTV owners are cheering you on, Have Fun and Enjoy,,,
      DrFunk
        • soundchaser Just Startin' 8 posts since
          Feb 6, 2007
          Dec 26, 2012 2:17 PM (in response to pcep)
          Re: New JTV-69 Day!
          One of my favorite things about owning a Variax is the ability to learn songs I never could have before, due to alt tunings.  Try this one on 12 string in Open C, CGCGCE; Question by the Moody Blues.  Your ears wont be able to tell the difference between the JTV and a 12 string.
  • dgnyberg Just Startin' 24 posts since
    Oct 21, 2010
    Dec 27, 2012 6:26 PM (in response to pcep)
    Re: New JTV-69 Day!
    I haven't got a JTV, yet, but for my older Variaxes both the electric and acoustic,
    I changed the Banjo tuning from standard to Nashville and the difference is night and day!
    The lower strings kind of deaden the tone of the banjo, to me.
    Another thing you might consider is doing a retune of one of the 12-string models to mandolin tuning through Workbench.
    I'm not sure how it would sound, but it might work well enough. Just a thought.
    I am planning on ordering my JTV at the end of January.
    Hope the ideas lead you to some fun experimentation!
