201 Views 2 Replies Latest reply: Dec 7, 2012 9:03 AM by BigChas52 RSS
tjung Just Startin' 1 posts since
Jun 14, 2009
Dec 6, 2012 4:49 PM
toneport UX1 - sound is intermittent?
I have a toneport UX1 that I have used many years with no issues on my desktop (Dell win7 32 bit) however when I use it on my laptop (Dell win7 64 bit) the sound will drop out for a few seconds then come back on again. I have installed the latest drivers but it didn't help. I have tried different USB ports on the laptop with no difference. Could it be a latency adjustment ? I read somewhere that the "buffer" can be adjusted but I don't know how to access that adjustment. If you have experience with this issue your help would be much appreciated. Thanks !
  • hulbert Iknowathingortwo 375 posts since
    May 12, 2011
    Dec 7, 2012 4:40 AM (in response to tjung)
    Re: toneport UX1 - sound is intermittent?
        You can adjust the buffer by either opening up Pod Farm and going to 'File', 'Preferences', 'Hardware', 'Tone Direct Settings', or by going to the Line 6 folder and then the tools folder and open Line 6 Audio-Midi devices. The sliding thing at the bottom adjusts the buffer. If you move it to the left you get less delay and more needed from the CPU to run it. If you move it to the right, there will be more delay but less pressure on the cpu. Try moving it fully right and apply etc. and possibly restart computer (I don't think it needs to restart but just in case) and see if the problem goes. You will then possibly notice the delay in sound now between playing and the sound coming out, but if the problem has been fixed then move it down to the left until you start having the problem again and then keep it at one above that (or whatever you prefer).
    You could also have a look at these pages for other ways to get things to run smoother:
    http://line6.com/support/docs/DOC-2085
    http://line6.com/support/docs/DOC-4282
    Hope something helps you get it to work smoother. Let us know if no luck.
    God Bless,
    David
  • BigChas52 Expert Line 6 User 2,315 posts since
    Mar 12, 2007
    Dec 7, 2012 9:03 AM (in response to tjung)
    I recently had the same problem with a new Windows 8 desktop.  I fixed it by going into the Windows advanced power settings and setting "USB selective suspend setting" to "disabled".  I hope this works for you as well.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
