Dec 7, 2012 11:47 AM
DT50-112 or DT50-212
Like (0)
Currently, I have an HD500 and hate the sound of my current amp. Would I gain anything by purchasing a DT50-112 vs a DT50-212 amp?
Based on you experiences, is it worth the extra bucks?
Thanks
the DT50 is a great amp! i have the 112, the biggest difference with the 212 is the second speaker is a vintage 30, so it's more than just a second speaker, since it has a different voice... having said that i'm plenty happy with the 112.
I think so...but I'm probably biased as I have a DT-50 112 and a HD500. ![]()
Just ordered a 212. Hope it arrives this week. I'm looking forward to some amazing sounds.
Thanks for the responses.
Just received my DT50 212. Love it. Just updated to the latest firmware. Like the idea that I can create tones using Midi Editors and not have to plug in my HD500.
Question: Does anybody find that there is a lot of background noise/hiss even at the minimal volume levels?
If you are getting a fair amount of hiss, you might have a bad 12ax7. It is common for Chinese tubes to be noisy, so try replacing it. It should be covered under warranty within 90 days of purchase. If you have another tube around, try swapping it out to see if that is the problem.
BTW- If your amp is in Class A mode, it will be noisy. That's just the way is is. It should be very quiet in Class AB mode. The noise isn't a problem in Class A at normal gig levels.
Got the same problem with my 112 (one of the very first unit). I finally returned it and bought a real bogner (used)!
I posted on this forum about the problem. I even attached an audio sample on which you could clearly hear the noise.
funny it shows this as your first post...
Oops, used my other account for this post (teleplayer_fr) http://line6.com/support/message/242715#242715
I even didn't remember that I had 2 accounts. Will close this one ASAP.
The sound sample is there : BruitdeSouffleDT50112.mp3 (10 secs in standby then on)
