948 Views 17 Replies Latest reply: Dec 24, 2012 2:52 AM by hurghanico RSS
pforsell Just Startin' 16 posts since
Nov 19, 2006
Dec 9, 2012 9:57 PM
pod hd 500 headphone settings?
Hi All,
I have an HD 500 and I'm having a hard time dialing in any heavy distortion tones with headphones that don't sound artificial. Something has to be wrong because I'm getting more realistic (sounding and feeling) tones on my POD 2.0! This is at low volumes also. I play a lot at night when kids are sleeping. My headphones are very good but they don't exactly fit the specs I have read about in the past. They are Eartools RP-21s. I have used a lot of downloaded patches on the site, and I just can't get a nice tone. Everything sounds harsh with a very unnatural pick attack. I'm getting worried about my purchase and I have read so many great things about the HD500. Thanks in advance for any advice. The specs on the phones are:
Sensitivity: 100dB ±3dB
(1mw @ 1kHz)
Frequency Response: 10Hz – 22kHz ±3dB
Fantasy Response: .001Hurts – 12GHurts
A Good Caning
Transducer: 50mm Dynamic
(Neodymium)
Impedance: 32 Ohms ( 15%)
  • lforward00 Just Startin' 34 posts since
    Jun 18, 2007
    Dec 10, 2012 11:03 AM (in response to pforsell)
    Re: pod hd 500 headphone settings?
    I have the Pod HD300 and after a full year of playing (at home), I still cannot get good tones on either of my two sets of headphones: Sennheiser 280 Pros (impedance 64 Ohms) and Audio Technica AD500 (impedance 64 Ohms I think)
    I can't seem to rid myself of fizziness or boominess or mid-range harshness. I live in a world of tone mediocrity with this unit.
    Sorry, I can't help you but I will tell you that my solution is a Zoom G5 which I will be getting as a Christmas present. I can't wait.
  • hurghanico Just Startin' 399 posts since
    Jan 28, 2007
    Dec 10, 2012 1:14 PM (in response to pforsell)
    best phones for audio production (not just for listening) are all hi-impedance: in the 150 - 600 ohm range
    they can handle much better high audio peaks without going into distortion
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Dec 10, 2012 11:38 AM (in response to pforsell)
    When using headphones, make sure your HD500 Output is set to Studio.
        Jan 28, 2007
        Dec 10, 2012 2:17 PM (in response to pforsell)
        I don't know if you did it already or not, but just in case, you should also try to connect your HD to a PA or some external FRFR amp to hear the real sound of this machine, then with the right cans that sound should be almost identical in your ears (except for the obviously missing part due to the surrounding ambient influence)..
  • mojah63 Just Startin' 6 posts since
    Apr 21, 2007
    Dec 10, 2012 4:21 PM (in response to pforsell)
    Don't use the headphone out on the HD. It sucks, line 6 dropped the ball on this one. The old Pod 2.0 sounded much better. Just use the line outs into a headphone amp or good stereo amp and plug your cans in to that. It's like night and day. I've tried quite a few cans through the HD headphone out, it's almost useless...
    Also there is a popular noise reduction technique that says to select input 2 to Variax to lower your noise floor. It works BUT I've found it can mess with your
    distortion sound. It almost sounds like the difference between 16bit and 24 bit sampling. The treble gets harsh and hard on some amp models. Set input 2 to same and live with the little bit of extra noise. It sounds so much better esp through cans. The SM57 can be harsh too, try a ribbon mic and turn up your treble on the amp.
          Jan 28, 2007
          Dec 22, 2012 11:55 AM (in response to pforsell)
          pforsell ha scritto:
          ...I plugged the pod hd500's unbalanced outputs into the headphone amp and there was little to no sound with the headphone amp cranked, and it sounded horrible...
          when you connected the HD500 1/4 unbalanced outputs to the headphone amp, did you set also the switch "1/4 OUT" to "LINE" (it is near the volume pedal)??
              Jan 28, 2007
              Dec 22, 2012 2:39 PM (in response to pforsell)
              ...The amp is a headpod 454. I figured that should work.
              http://www.aphex.com/aphex-products/454-headpod-2/...
              since your headpod 454 has only balanced inputs you need 2 balanced cables which are TRS to one end and XLR to the other end, the guitar 1/4 standard jack cables don't work
              give a look here as an example: http://www.sweetwater.com/c813--Balanced_Cables_XLR_to_TRS
                    Jan 28, 2007
                    Dec 23, 2012 4:55 PM (in response to pforsell)
                    to be honest I am fine just by connecting my old AKG K141 (600 ohms) headphones directly to the pod phones output ..
                    I never felt the need for an external
                    headphones amp .. I think I would find it cumbersome ..
                    one of the nice things of the pod is that it is easily transportable, a complete guitar rig in a single box, just plug and play..
                    I add a tip for you:
                    never use the patches you download as they are ..
                    at least 3-4 things that you must always adapt
                    to your guitar (which is different from that of the person who made the patch) in every patch are:
                    - the noise gate threshold (this setting if not suitable, can affect badly your pick attack and notes decay)..
                    - the drive (distortion level)..
                    - probably you'll have also to tweak a little the amp eq settings..
                    - give a look also to the compressor (if any) settings.. it influences very much the pick attack too, but also the notes sustain..
                    the above tip also applies to the factory presets
                    • davidgedda Just Startin' 4 posts since
                      Jan 7, 2011
                      Dec 24, 2012 1:57 AM (in response to hurghanico)
                      Akg k141= 55 ohms impedance not 600 ohms
                      Typesemi-open, dynamic headphones
                      Sensitivity101 dB/mW, 114 dB/V
                      Frequency range18 to 24,000 Hz
                      Rated impedance55 ohms
                      Max. input power200 mW
                      Earpadsleatherette and velvet
                      Cable3 m single-sided and 5 m coiled cable (99,9% oxygen-free); plug-in cable on headphones (mini-XLR connector)
                      Connectorgold plated stereo mini jack
                      Adaptergold plated 1/8" to 1/4" screw-on adapter
                      Net weight (without cable)225 g (7.9 oz.)
                      Shipping weight550 g (19.4 oz.)
                      Patent(s)Varimotion – multiple-thickness diaphragm for dynamic transducer (Patent no. AT 403.751, US 6,185,809, EP 814.637 (DE, DK, FI, FR, GB, IT, NL), JP 3.927.651); Acoustics slot resistor for dynamic transducer (Patent no. AT 408.706, US 6,639,991, ZL 01116806)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
