290 Views 17 Replies Latest reply: Dec 19, 2012 9:57 PM by anonyrat RSS
kevanprince Just Startin' 61 posts since
Dec 14, 2009
Dec 10, 2012 8:07 PM
Anyone using an HD500 with an M13 (or 5 or 9)?
I had an m13 for use with my tube amps, but recently got another HD500 (sold the original one and am coming back). I was going to try to build a Bonamassa/Johnson style patch with dual amps, but after adding a few effects I ran out of DSP (I've since learned that the spring reverbs use a lot of DSP). Anyway, I thought I could easily use both the M13 and HD500 together, maybe a simple connection in the HD's loop and using the M13 for mostly reverbs, delays, etc.
Anyone doing this? Got any good tips/tricks or general discussion on the topic?
    Dec 22, 2006
    Dec 10, 2012 8:19 PM (in response to kevanprince)
    Re: Anyone using an HD500 with an M13 (or 5 or 9)?
    haven't tried it with the m13, but the m5 wired in the loop stereo, and both midi connections was a breeze...
    as long as you save your tone after you adjust the m5, the hd500 will remember it and switch to the saved effect when you call up the preset.can't say that the m13 would work identically (it's a bit older than the m5) but i was surprised out how seemless and easy it was getting them to work together.
        Dec 22, 2006
        Dec 11, 2012 8:17 PM (in response to kevanprince)
        yeah you have to use a TRS to 2xTS insert cable...
        but yeah... i think that the M5 (in my case) send the midi patch # to the hd500, as long as you save it, it sends that back out when the patch is selected.... in my experience it was that simple...
        i don't tend to need all the DSP as i don't use dual amps, and use the pre's with my DT amp... so i basically did it as a proof of concept and played with it like that for a few weeks.
  • cgtrox Expert Line 6 User 1,638 posts since
    Jan 25, 2007
    Dec 10, 2012 10:21 PM (in response to kevanprince)
    Oh yeah. I use my HD Pro with my M9 and it works great! I use it for all of the "post" effects (mods, verbs, delays, etc.) and it works like Zap says with the MIDI connected! the good thing about my rig is I never run out of DSP. I use the "pre" models and real guitar cabs, all of my patches are dual amps!
    cgtrox
      Dec 22, 2006
      Dec 11, 2012 5:25 AM (in response to cgtrox)
      dammit! now the m9 is gonna have to go on the christmas list...
      the pro already is... just better suited for my studio work (have the 300/bean/500)
      may as well get a 400 while i'm at it! hahah
      • Notooth Just Startin' 6 posts since
        Jan 25, 2007
        Dec 12, 2012 3:13 PM (in response to kevanprince)
        I also have succesfully used the M13 in the HD500 effects loop with a stereo TRS cable.  It worked great when I placed effect loop before the amp sim but noticed clipping when the el was placed after the amp.  That was easily adusted through the send.return levels in the effects loop.  I enjoyed having no restriction on DSP.  I have since moved away from this setup since it took up to much floor space.  I moved to more single amp patches to keep my pedalboard as compact as possible.  BTW I purchased an L3m and use that in the back line.  No AMP for my cover band.  I prefer the FR/FR setup so what I hear from my L3m is for the most part what the audience is hearing through the mains.  But for any of you DSP crazies out there I recommend highly the M pedals if you have the floorboard space.  The M13 effects to my ears sound identical going through the HD500.
        Jan 25, 2007
        Dec 18, 2012 10:06 PM (in response to kevanprince)
        @ kevanprince, I'm using a Crown XLS1000. Just nice clean power! Pretty neutral, no color. Let's the cabs voice come thru...
        cgtrox
  • anonyrat Just Startin' 62 posts since
    Dec 25, 2011
    Dec 13, 2012 3:43 PM (in response to kevanprince)
    Remember that the HD500 doesn't act like a good MIDI controller.
    If you set up an FX footswitch(HD500) assigned to the FXLOOP to select the preset on the M9 etc - then you have to press the FS to send the MIDI message. This is how I am doing it currently - not ideal..
    But it does mean that I can select the preset on the M9 that I want. So lets say that on the M9 you set up:-
    Preset 1 to a slap back delay
    Preset 2 to Spring Reverb
    Preset 3 to Multi Head Delay
    Using the FS on the HD500 I can set HD500_Patch_1 to 4 to Preset 1 on the M9 (first 4 patches to slap back)
    *** To do this method the MIDI channel has to be different from the base channel and not OMNI
    The other way is to set the M9 to the HD500 base channel (usually 1) or OMNI
    Now this sends a Program change message WHENEVER you select a new preset on the HD500
    Therefore using the above...
    Select Patch 1 on the HD500 selects preset 1 on the M9 (slapback)
    Select Patch 2 on the HD500 selects preset 2 on the M9 (Spring Reverb)   OH NO I WANTED SLAP BACK!!
    Select Patch 3 on the HD500 selects preset 3 on the M9 (Multi Head Delay)  as above
    64 patches in a setlist - 24 presets in an M9 - so patch 25 starts back to slapback etc. Imagine how frustrating this method is...
    My new solution is that I have ordered a MIDI Solutions MIDI mapper to map program change messages to what I want.
    Will have to wait for that and see how that goes.
    Dec 25, 2011
    Dec 19, 2012 9:57 PM (in response to kevanprince)
    OK in a post above I said that I was going to get a Midi Mapper - well it has arrived and this is my feedback.
    FYI: The unit is a Event Processor Plus from MIDI Solutions ( I got the plus because it allows 32 settings (in my case mappings))
    Whilst I was awaiting the arrival of this unit I downloaded the software (which you have to do anyway) and had a look to see if it was going to do what I wanted. Bit late I know ...
    The program is just a list of MIDI instructions that when you right click on allow any changes to be made in an easy to use panel.
    You may remember my dilemma, Select patch 1 on the HD500 sends out program change 0, patch 2 sends pc 1 all the way up to 64 patches. Sequentially duh
    Now I had set the HD500 patches to require the following presets on the M9
    HD500           M9
    1-4                 5
    5                    0
    6                    8
    7                    9
    8                    7 etc...
    Using the event processor plus I wrote the mappings in about 10 minutes.
    The unit takes a midi cable IN from the HD500  which supplies power (so no extra power needs) output goes to the M9
    This really works well for me and has allowed me to really integrate the M9 into the dream rig in a creative way.
    So in the above list selecting HD500 patch 2B (#6) it will change the M9 to preset 8 (2A in folder 2)
    Cons: The Event processor only allows 32 settings (think instructions or mappings) - so to map each preset in the HD500 would require two units, daisy-chained. But, in reality
    this was not a real requirement as I set a default preset on the M9 (say 0) and then set all program changes to 0 except certain patches or blocks of patches. Out of 32 I used 17.
    So not a serious con.
    Pros: No power needed, east to set-up, works very well, gives me a super dream rig that L6 couldn't...
