294 Views 8 Replies Latest reply: Dec 13, 2012 10:34 AM by masfe3 RSS
masfe3 Just Startin' 5 posts since
Dec 6, 2012
Dec 12, 2012 12:59 PM
Pod hd 500 pre/full amps
Hi, i'm connecting the pod directly to headphones. Which ones should i normally use, the full amps or the pre amps on the pod?
Thank you
Marco
  • BigBob-Irwin Just Startin' 9 posts since
    Feb 11, 2012
    Dec 12, 2012 1:09 PM (in response to masfe3)
    Re: Pod hd 500 pre/full amps
    Full should be used for headphones
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Dec 12, 2012 2:35 PM (in response to masfe3)
    ... and make sure the HD500 Output mode is set to Studio.
      Dec 22, 2006
      Dec 12, 2012 7:06 PM (in response to masfe3)
      *IF* it works... your theory would be more than likely right... (tone is ALWAYS subjective)
      keep in mind though, switching from pre to full, may go over the DSP limit... and the tone may not work at all...
    • PremiumJones Iknowathingortwo 238 posts since
      Mar 29, 2008
      Dec 12, 2012 11:43 PM (in response to masfe3)
      It will work fine. Will it hcange the tone? absolutely. Will that change be an improvement? hard to say..... but it will certainly work.
      • johanneszab Just Startin' 29 posts since
        Mar 3, 2011
        Dec 13, 2012 12:40 AM (in response to PremiumJones)
        To tonal topic, sure, it might sound different, but it will sound different for you anyways, regardless of the amp state, because no one knows what output method was used by the author if you download a preset. Since i've got the HD Desktop and use headphones most presets have a way to less bass for my taste. And that might result from my output device. So i mean, interchanging presets is a nice feature, but you'll most likely have to manaully fine tune them anyways.
        I'm not sure, what you mean by "it will work fine". It will certainly not keep your settings if you switch from a Pre to a Full Amp or vice versa  if you changed the settings (i.e. you've loaded a preset). Somehow, for me, it always fetches the settings for a specific amp i've had upon booting the device.  Just try it, for me, it works somehow, but certainly not nice. Maybe it is different on the HD 500, i don't know.
        So, if you run into the same problems, you can tryout to set the pre amp to a full amp directly in the preset using my tool (or vice versa): http://www.jzab.de/content/pod-hd
