138 Views 3 Replies Latest reply: Dec 18, 2012 6:57 AM by phil_m RSS
Giax1974 Just Startin' 54 posts since
Dec 6, 2007
Dec 17, 2012 12:09 PM
Roctron Patchmate and Line 6 m13?
I was thinking on getting a Rocktron patchmate Loop 8, as it has midi and 8 loops, it says it can control amp switching too which is awesome...
IF patchmate controlling M13, can I just press a footswitch, and it can turn any of my 12 presets that I use in latchmode + other pedals + AMP channels via footswitch cable???
If this piece of gear can do that, it can be very useful. But...
Should M13 control PAtchmate or Patchmate control M13?
my set up is M13 + 8 analogue pedals and MEsa ElectraDyne and/or Orange DualTerror.
Thansk in advanced as usual!
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Dec 17, 2012 1:49 PM (in response to Giax1974)
    Re: Roctron Patchmate and Line 6 m13?
    I don't believe the Patchmate itself is a MIDI controller. I think you can access the eight presets with the footswitches, but beyond those, you have to use an external MIDI controller to get the full number of presets. I don't know if it sends MIDI PC messages when you select a preset on it or not. It's not clear from the manual.
    You could use the M13 to call up a limited number of presets on the Patchmate if that's what you want to do. If you want to be able to take advantage of the total number of presets of the Patchmate, you'd need an external MIDI controller.
        Jan 25, 2007
        Dec 18, 2012 6:57 AM (in response to Giax1974)
        The M13 sends out a unique PC message when you select one of its scenes, so that in turn should be able to call up presets on the Patchmate. You'll have to look at the M13's Advanced Guide and the Patchmate's manual to see how these two correspond to each other. They both have static MIDI maps, so you're limited by that, but if you only want to access a limited number of presets on the Patchmate, you should be alright.
        I'd say the easiest thing to do is simply connect the M13 to the Patchmate with a MIDI cable (from M13's MIDI out to Patchmate's MIDI in) and see what happens when you select scenes on the M13.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
