114 Views 10 Replies Latest reply: Jan 2, 2013 5:30 AM by fflbrgst RSS
mveseskis Just Startin' 6 posts since
Jan 7, 2012
Dec 19, 2012 8:42 PM
I need help! I am new to the FBV online controller.
I just bought the FBV Shortboard MKII and I signed up and did all the updates.  I now have the FBV Control app open and I am messing around in the control properties but I haven't a clue what I need to choose!  I understand the Control Column.  But I haven't any idea as to what I choose in MIDI Command, Value, Port, Channel, Switch Mode,etc.
Any help would be much appreciated!
  • fflbrgst Power User 1,292 posts since
    Mar 6, 2011
    I don't use this myself, but I would assume those settings would have to be made based on what you are trying to control (software, MIDI device, etc).
  • Remlap Just Startin' 8 posts since
    Dec 16, 2012
    MV,
    I wouldn't really fool with the FBV control software unless you are planning changing the functions of the footboard.
    You can use the footboard as is. You're likely just wanting to learn how to change and organize your presets for your footboard?
    If you want to assign different presets in place of the ones you have, you can do that through the amp first.
    I'm new to the whole thing myself and have had to go through quite a learning curve. Some simple how-to vids by Line 6 would eliminate
    a LOT of call-ins to tech support as well as questions on these forums.
    I figured out the setup sort of by myself and poking around.
    I have the MKII with a Spider IV 150 amp. If that's what you have and still need help with setup
    let me know, I'll type out some instructions for you to get the presets you want on to your A,B,C,D channels
    so you can at least select them with your FBV.
        Dec 22, 2006
        there really isn't any settings on the FBV's.... its a controller.. the settings are on your amp...
        learn your amp, and the controller will be easy.
        Dec 16, 2012
        Dec 22, 2012 11:19 PM (in response to mveseskis)
        Re: I need help! I am new to the FBV online controller.
        MV,
        I'll show you what I've learned so far. I think I can help you get your presets on lined out.
        Your amp likely has all of the user, song and artist presets like mine (Spider IV 150) I assume.
        And it sounds like you have the Shortboard? I don't know the Express at all, but here's how you can access
        all of the presets onboard and put them on your A,B,C,D channels.
        1) First of all, to understand how this sort of works, the FBV does not store the sounds and presets. Everything
        is stored and handled on the amp. The footboard merely flips the settings on the amp as needed.
        2) On your amp you have literally hundreds of preset sounds and effects. Some are 'user' settings, just random effects
        that they have loaded on to your machine to browse through. You also have 'song' presets which have been loaded
        on to emulate certain songs of different eras (50's, 60's 70' thru 2000's) to help keep you from having to manually
        tweak on these sounds. (You can still tweak and modify any of these how you would like and store them that way).
        You also have 'Artist' presets which have been tinkered by different band and studio musicians and addIed on.
        Also online there are many others that can be downloaded and the uploaded using the Spider Edit software for your amp.
        3) The first thing I did was to create a spreadsheet believe it or not, to help organize which sounds I wanted and where
        I wanted them. You have 64 spaces to save whatever presets you want. A bank has 1-16, B has 1-16, C and so on = 64.
        You can cycle through these using your footpedal instead of having to jack with your amp everytime.
        4) Now, to get to your presets. Your amp should have a tiny yellow display showing the preset currently being played.
        Just below that, there is also a little black round 4way multipad to cycle through your presets (you're going to have to do all of this through the
        amp first, so bear with me). EVEN THOUGH YOUR AMP HAS MANY PRESETS, YOU CAN ONLY CONTROL THE ONES ON A,B,C,D BANKS 1-16.
        That gives you 64 effects to work with. But don't fret, you get to decide what presets you want in your top 64. That's what I'm going to explain.
        If you want to take these off and add the others on your amp here's how you go about it.
        If you look at the little display, you might be on 06A. That is bank A effect #6 (of 1-16).
        The little black multipad has 4 arrows - left, right, up, down. If you press the 'down' arrow, you should be able to
        change/select a different effect. You can cycle through 1-16 on the A bank. To get to B bank or C bank, you have to use
        the little "Presets' knob right next to it. You should notice you go from 6A to 6B to 6C, etc. That gets you to your 64 presets.
        5) Now, to access even MORE presets, Use the round MF pad and use the 'right' (R) arrow. You are no longer accessing
        your 64 'controllable' effects. You should now be in the 'Artist' presets. These are ones that were created by different bands and artists.
        You can still play all of these by manually navigating to them, but I will soon show you how to add
        any of these 'off the grid' effects to your list of 64 so stay with me. There are gobs of these to play and review. It took me hours
        to cycle through and goof with each of these to come up with ones that I like and dont'. (Hence the spreadsheet. You'll want to take
        some sort of notes on ones you like and don't like, ESPECIALLY note the ones you like and where to find them).
        There are many artists, and each artist has many different tones they have created so the list goes on.......
        When you show an artist name, use the little rotating 'preset' knob to cycle through that artists' sounds.
        6) For even more fun, use the MF pad again and press the R arrow to go to "Song" presets. These were created to emulate
        guitar for certain songs from the 50's, 60's 70s and on as mentioned before. If you're on the 50's, again use the preset knob to
        cycle through the different songs (again keep notes on which ones you like).
        7) So now, organizing presets into your 64 spots. It has been recommended to organize these by bank.
        A,B,C,D. Something like this. Bank A would contain all of your 'clean' tones. Bank B rhythm tones, Bank C 'leads'. Bank D, flanger/wah effects.
        Something like that, however would suit you best.
        Here's where I goofed a bit. There were several of the original 64 presets that I wanted to keep and use. I began moving things around
        and inserted some tones in their place by mistake and ended up having to find them again to restore them. Works best if you 'map out' your
        A 1-16, B 1-16 on paper or spreadsheet to know which spots to use for which effects. Because as you start 'storing' different effects on here,
        you are in effect, replacing the one in that given spot. You can first move it somewhere else if you would like to keep it.
        For instance I might move my original presets to spots 16, 15 and 14 just to get them out of the way. So I can add others in 1-13 on that bank.
        (And don't worry, if you happen to insert a preset over one that you intended to keep, they are pretty much all available on your amp somewhere)
        8) Okay, how to finally start moving and storing these. First, navigate to the tone you would like to keep (you need to have a landing spot in mind, A1, B3 or wherever you are going with it). When you have the tone showing on the screen 'let's say 'song, 1960's Brown Sugar'.
        If I want to add it to B1, (there should be 4 buttons on the face of the amp A,B,C,D) you push and hold in the B button on the amp for just a couple of seconds.  When you press and hold, All of the A-D lights should start flashing, you can let go. Your display should now show 'SAVE 15A or something for instance. Ignore the SAVE 15A part, what you want to focus on is the FAR right number in the display.
        Before you do anything else, use the Multipad up/down to select the 'number' you want it to go in. (For instance B1 in our example, scroll down to change the number on the far right to 1). Now you want it to go to B-1 right? Now that you have 1 selected in the display, just simply press the B channel button that is flashing. Congratulations! You just saved your 'Brown Sugar' to position B1 on your bank. You can now access this tone with your footpedal. Repeat these steps up to 64 times to fill up your banks.
        I hope this helps.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
