Dec 24, 2012 6:44 AM
Van Halen Amsterdam Tone POD HD 500
Like (1)
Hi there!
I reached to this incredible tone by chance, last night I was listening to the song Amsterdam by Van Halen, and had the feeling that the ENGL model would fit this tone (yes, ENGL)... So I used some tricks to get rid of the ENGL's boom and massiveness, and added some treble to obtain that killer nasty-glassy tone of the album Balance.
http://line6.com/customtone/tone/222258/
The trick here is to add a Blue Comp Treble in front of the amp to illuminate it, and use a couple of parametric EQs to get rid of some frequencies.
As usual, I use a 4 Band Shift EQ to sculpt the tone firstly, and then I work on specific frequencies using the Parametric or Mid Focus EQ.
I also use VERY LOW GAIN (20%) on the amp.
Finally, I added just the exact amount (mix) of Analog Flanger to make it perfect!!!
NOTE: This tone was made to use with COMBO POWER AMP OUTPUT MODE
Other Output modes may sound very bad, I tried Studio Direct through my Thonet & Vander system and sounds very trebly and lacking of warmth, like an artificial tone; very bad... So if you want to "translate" this tone to use it with other output modes, you´ll have to tweak it perhaps a lot.
Hope you like it!!!!
P.S.: JIM: give it a try, I know you use Combo Power Amp mode with your JVM!!!
Cheers!!!
Gracias fechart, en unos dias llegare a mi casa y lo probare.
te enviare alguno de mis preferidos.
Thank you, in a few days will arrive at my house and I'll prove.
I'll send you some of my favorites.
De nada Juanes, espero que te guste!
Saludos!
Flavio
You´re wellcome Juanes, I hope you like it!
Cheers!
Flavio
Holas estoy probando tu patch, te adjunto algunos de los mios.
http://line6.com/customtone/tone/217381/
http://line6.com/customtone/tone/216448/
http://line6.com/customtone/tone/219684/
saludos.
