303 Views 9 Replies Latest reply: Dec 29, 2012 6:17 AM by jimsreynolds RSS
chaos69 Just Startin' 5 posts since
Apr 1, 2007
Dec 28, 2012 8:48 AM
POD HD 500 Amp control with midi solutions relay controller.
I've just bought the midi solutions relay controller and i've a problem about send msg to control midi relay controller by POD HD 500. i've a lot of try to setup POD HD 500, it can't control amp.
My amp H&K tubemeister 18 head
My setup
POD HD 500 midi out > midi solutions relay controller > 1/4" mono > H&K Footswitch channel
After assigned to FS-1 on HD 500 and after that try to push, midi relay box 's ligth is flashing and don't have any responses.
Please kindly suggest me, i really don't know what's wrong? T-T
Thank you.
midi solution link : http://www.midisolutions.com/prodrel.htm
  • jimsreynolds Power User 2,227 posts since
    Jun 27, 43450
    What are you trying to do?  Use FS1 within a patch to change amp channels?
    It looks like the Midi Solutions Relay (hereafter 'The Relay') can be programmed to respond to either Midi PC Patch change or Midi CC Controller change  messages (amongst others).  The HD500 can send either.   The HD500 automatically sends out a PC message whenever you select a patch corresponding to the patch number (0-63).   If you do not want this behaviour, and always want to change channel using an assigned FS1, then can I suggest that you use a CC Message as this will make things clearer to work with.
    You program the  the Relay to respond to the CC (or other message) using the software here --> http://www.midisolutions.com/ptprocessors.htm .   This software works on 32-bit Windows only.  The software sends a 'SysEx' message to the Relay that sets what messages the Relay will respond to.  This is a one off operation and you will need to work this out yourself (I am running 64-bit Windows ).  Make sure that you set the Midi Channel on the Relay to 1.  Make a note of the CC Message number and value that you have configured the relay to work with.
    Now, run your Midi cable from the HD500 Midi Out to the Relay Midi In.  Go to your preset and configure FS1 so that it sends out the Midi CC Message number and value when you press the relay button.  Make sure it sends the message on Midi Channel 1.  You may need to use a Midi CC Toggle message to toggle back and forward between the channels on the amp.  I cannot tell.
