179 Views 5 Replies Latest reply: Dec 31, 2012 9:20 AM by dboomer RSS
crott2010 Just Startin' 3 posts since
May 14, 2010
Dec 30, 2012 8:51 AM
Another G90 with problems...
I've had my G90 for a couple months, it has maybe ten hours on it. A couple of days ago the audio started cutting out when I turned it on. The RF LEDs are all green and do not drop out it is just the audio that cuts out. I've been through the trouble shooting section and have had no luck. I've tried every channel with the transmitter locked, high/low power, every antenna, changed the batteries, changed power source, shut off my wifi, took it out of my rack, and replaced output cable to my pre amp. When I use a cable and plug directly into my pre amp, I have no problems so it is definitly the G90 that is the problem.
Kind of disapointing to have a $600 boat anchor in my rack with limited use...
  • dboomer Line 6 Support 1,997 posts since
    Oct 13, 2008
    Dec 30, 2012 5:10 PM (in response to crott2010)
    Re: Another G90 with problems...
    If the RF LEDs are green then the transmitter is transmitting and the receiver is locked on to it.
    Does the Audio LED on the transmitter stay lit or does cut out?
    The most common cause of problems like this is a broken input cable.  Can you rule that out?
