Jan 3, 2013 5:32 PM
Not sure if FBV Toe Switch has piece missing?
Like (0)
I bought a FVB MkII Shortboard used and when I try to toggle between Wah & Volume it does not work. After reading many post I understand that it is not always easy to push the toe switch. Looking under the pedel it appears that some may be missing or broke. There is a sharp/shallow indention on the metal pad/switch that indicates, to me, that something is missing. Any suggestions?
Max forward position:
"Max forward position" - the little tab should actually contact the round sensor/switch on the base at this point - your pictrue shows a gap (maybe just for photo?) Maybe you are unable to press the toe down all the way for some reason?
