166 Views 5 Replies Latest reply: Mar 14, 2013 1:33 AM by drowner77 RSS
seabreeze666 Just Startin' 6 posts since
Sep 27, 2010
Jan 6, 2013 6:35 AM
Acoustic sounds routing
Hi, I have a DT25, HD500 and a JTV59. Can anyone recommend a good way to route the acoustic guitar sounds to the PA from either to HD500 or the amp?
I want to switch a patch from an electric sound through the amp to an acoustic sound through the PA. Changing patch is no problem so not expecting to do it within the patch.
Thanks.
  • msttomservo Just Startin' 11 posts since
    Nov 13, 2010
    Jan 6, 2013 7:43 AM (in response to seabreeze666)
    Re: Acoustic sounds routing
    I have the same rig and I followed the answer provided about using he FX loop in this post and it worked fine:
    http://line6.com/support/thread/89929?tstart=0
  • Currently Being Moderated
    Jan 7, 2013 11:18 PM (in response to seabreeze666)
    I agree with msttomservo, FX loop is IMHO best way to go. You can also have regular pickups - electric guitar going to DT25 and piezos - acoustic guitar going to FX loop at the same time using dual signal path  - just use fx loop in path with acoustic guitar. With propper settings you can blend those two sounds or do nice and fast changes from eletric to acoustic sound.
  • segueking2 Just Startin' 8 posts since
    Nov 9, 2007
    Feb 24, 2013 9:29 PM (in response to seabreeze666)
    Here are photos of the 2 tones. You'll notice that any effects after the amp need to be on one path otherwise any effects after the amp come through left and right outputs
  • SWoRd Just Startin' 48 posts since
    Jun 5, 2008
    Mar 4, 2013 5:58 AM (in response to seabreeze666)
    I just ommit the amp completely on acoustic patches. Then there will be no sound routed to the DT25 even though it is connected. On electric patches I set the mixer after the amp to zero volume. That will turn off sound to the PA and only route the sound to the DT25.
    I've also created a second bank of patches with the only difference that the volume is not turned down in the mixer after the amp. I use that for playing without the amp if I don't want to drag it along. Then I get all the sound through the PA using just the JTV and the HD500.
    Good luck with the programming.
    Best regards
    Soren
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
