Jan 8, 2013 12:35 PM
G90 with a Sennheiser E908 ?
Like (0)
Hi
I have a g90 system that I would like to use together with my Sennheiser E908 sax microphone.
Anyone knows if this can be done?
I know I need to make a new connector.
Best wishes to all of you in the New Year!
Bendt Aaen
Hello Bendt
You will need to use the wireless version of that mic "e 908 B-ew" that uses "bias" voltage. The "phantom" version won't work, although I believe you could remove the preamp from the cable end and use it as the wireless version. You'd need to check with Sennheiser on that question.
Then just wire it to a Ta4F connector. Instructions are in the FAQ in the document section.
Thanks for the answer
I HAVE the "e 908 B-ew". I will try this when I receive the G90 In a couple of days.
Kind regards
Bendt Aaen
