69 Views 3 Replies Latest reply: Jan 13, 2013 2:22 PM by DickFoster RSS
Lemec Just Startin' 3 posts since
Sep 10, 2010
Jan 10, 2013 3:48 PM
Using TC Electronics G-Force with Vetta II
I have both...Trying to use them together via the effect loops. Have the 2 "Y" cables ...but...TC G-Force get signal but no sound return to the vetta II.
When i route the loop in parallel i get the dry sound again but no fx from teh TC G-Force...
Any ideas/comments regarding this issue ?
Thank you in advance,
Best regards,
Lemec
  • DickFoster Just Startin' 98 posts since
    Jan 26, 2012
    Jan 11, 2013 9:35 AM (in response to Lemec)
    Re: Using TC Electronics G-Force with Vetta II
    Both channels? If you're sure signal is going in on both channels then I'd first check the input jack to ensure that it is letting the FX Ret Sense line go high to the DSP, you should get about 3.3V at the junction of R37,R63 and C96 which is the sense pin on the jack. If thats OK, next I check the buffer amp outputs U10 pin 1, right and pin 7, left channel for signal. Next would be the analog to digital converter chip U16 and the signals it needs to function.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
