221 Views 14 Replies Latest reply: Jan 19, 2013 2:20 AM by alfmetal70 RSS
alfmetal70 Just Startin' 104 posts since
Feb 3, 43473
Jan 16, 2013 5:36 AM
Help: New amp Alto TOURMAXSXM112A‏
Hello, I bougth Alto TOURMAXSXM112A‏. Really very good amp quality thinking in the price and the sound, the best product for this price (like 550 dollars). I proved music, the guitar without the POD and sound beautiful. The guitar that I recorded and reproduce for the amp sound awesome (drive and clean).
I have a big problem with drives from the POD HD because now sound very "HD" and not natural, a very big difference in comparrison with my old valve poweramp or the little homestudio monitors.
Now sound like "perfect" and digital, I lost that natural sims.
  • Preamp sims sound so brigth and artificial.
  • Poweramp+pre sims the same.
  • The cabs sims are sounding so deep and unnatural.
  • The output is "studio/direct" and I proved the others also
  • All the setting are from factory (also I proved my personal settings)
  • The best options for the POD HD for my ears in the Alto are: "Full range" and "Flat".
Plase help me, is the first time that I use the POD HD with this type of amp, so a good presets made for this context can help me so much. I now that is not the amp because I proved also the Zoom G from a friend and sound better than the POD HD , for that I think that are my presets or the configuration. Greetings
  • PDKTDK Just Startin' 100 posts since
    Dec 24, 2011
    Jan 16, 2013 6:22 AM (in response to alfmetal70)
    Re: Help: New amp Alto TOURMAXSXM112A‏
    Make sure you are running the HD into the FX loop (not the guitar input) for your puposes.
    You may also want to check out this thread:
    http://line6.com/support/thread/74159
  • mlong Just Startin' 32 posts since
    Jan 29, 2007
    Jan 16, 2013 6:25 AM (in response to alfmetal70)
    I'm not sure if you are in the US, but I think you can get those for $299 all the time. I've seen good reviews for the price point($299).
      • hurghanico Just Startin' 399 posts since
        Jan 28, 2007
        Jan 17, 2013 3:13 AM (in response to alfmetal70)
        never buy audio equipment without first try..
        but maybe you were lucky .. who knows?..
        why have you abandoned your old valve poweramp given that it sounded so good?
        anyway you have now essentially a 400 W FRFR monitor, a totally different amplification solution, and obviously you have to make brand new patches, ar at least tweak the old ones which as they are can't sound absolutely the same as before..
        each time you change equipment you have to take into account some time for adaptation, that's normal..
        so don't despair
        take your time, and you'll see that good results will come
        the Zoom always sounds the same, even if you connect it to your grandmother's old radio..
        the POD, instead .. luckily changes a lot depending on what you connect to it, and where you connect it..
        it's a very dynamic and responsive device..
            Jan 28, 2007
            Jan 17, 2013 7:01 PM (in response to alfmetal70)
            Hi alfmetal70
            I understand very well the issue of weight, in fact it is one of the reasons why I use a pod and not more a complete real rig ..
            personally I'm not a big fan of typical stage monitor systems, or typical PA active speakers..
            I always preferred good keyboard amps as FRFR systems, I believe they are more robust than PA monitors, and resist better to high peaks that can be generated from devices like the POD directly connected to them..
            generally, a monitor is designed for a sound controlled by the mixer..
            a dedicated amplifier instead is designed to directly receive the raw signal of an instrument..
            I use a Roland keyboard amp and I like it..
            that said, and given your previous experiences, I think you'll feel in heaven if you buy a DT25 or DT50..
            but to be honest I do not know how much it would weigh
  • meambobbo Iknowathingortwo 1,702 posts since
    Dec 13, 2007
    Jan 18, 2013 3:21 PM (in response to alfmetal70)
    you can check out my guide for EQ and setup advice:
    www.foobazaar.com/podhd/toneGuide
