Feb 25, 2013 3:30 PM
DT50 / DT25 MIDI Configuration Tool for Mac
Like (0)
EDIT: New version available...
http://www.cunningham-photo.com/DTCustomizer
Please let me know if you find this app useful, and/or you would like to see some features added.
Thanks,
Cass
Please see this thread...
Could you please give rollo69, maker of DTedit for Windows the needed info to finish it?
http://line6.com/support/thread/89457
This is the status of his app:
Loading and saving is currently not enabled in the latest build but may be added in a later release.
I was not able to get some of the DT's values when syncing. Getting values from the amp is not documented at all and I hope that I will get some help from Line6 here. But I've not received a response from them yet.
Currently the following dials and controls will not show the current state of the DT:
The editor will alter these values only when you actually move a dial. If you don't touch these controls then the amp will keep it's stored settings.
The loading and saving will just take him some time.
Unfortunately, I believe I'm in the boat, as far as the "Hidden" Reverb amp states.
My app can send updates to the ReverbDecay, Pre Delay, Tone and Bypass settings, but the amp doesn't respond with these current states when queried.
My solution will eventually be to set these states to "last known" and keep them in the app. This should be fine, because there are no controls on the amp to change these manually.
Cass
As always, feedback is greatly appreciated.
Cass
Hi, thank you for this great app!
Unfortunately I can't seem to get it to connect to my amp... I'm using a midisport usb/midi cable (mac). Should I have both the ins and outs connected or only the amp's midi input? I just left both cables connected after the firmware update but the app doesn't want to connect. Incidentally I'm using channel 1... I am under the impression the channel doesn't matter but perhaps it does?
Also I am unsure whether or not the cab models should be set to none if just using the DT25 normally with a cab. And the "Use amp defaults" button is greyed out. So it also seems I won't be getting the correct operating class/tube config/topology for each amp model.
Hope someone can help!
False alarm, I reconnected and got it all working!! Fantastic!
Glad everything is OK.
BTW, the "Use amp defaults" checkbox is grey when the app cannot connect.
Cass
Hi Cass, yes, that all worked when it connected.
Regarding Low volume mode, I am making the changes in low volume mode - does the check box override the switch on the back of the amp? '
Obviously I want to make sure I can flip the switch to get back into loud mode when I am at rehearsal and it will work as normal. Could you let me know if I need to be careful making changes to this check box? I have a baby in the house and cannot check it for myself at this time.
Many thanks!
Martin
Hi Martin,
My experience with Low Volume Mode is that I can change it within the DT Customizer app, but it will revert and synch with the amp knob if the knob changes it's LVM position.
Please feel free to let me know if this is not what you experience. The more feedback everyone shares, the better we can all use the DT25 & DT50.
Thanks,
Cass
Will do! If I could make one request for a future update, it would be really useful to be able to edit the reverb parameters as well, especially the length.
Ah I'm using V0.7! Don't know how I missed the link to 0.8 above. Thank you!!
