105 Views 7 Replies Latest reply: Jan 22, 2013 6:42 AM by joel_brown RSS
TommyBBF Just Startin' 1 posts since
Mar 2, 2012
Jan 20, 2013 7:24 PM
Why I can't use patch from 500 400 ? I own Pod hd desktop
Why I can't use patch from 500 400 ? I own Pod hd desktop. Many patch are made for 500 but for the desktop version is very poor. I think is the same brain into the 2 models. Then I don't know why I can't play with patch all the family of the pod HD.
  • BigChas52 Expert Line 6 User 2,315 posts since
    Mar 12, 2007
    You can ue the HS500 patches with the HD.  You'll need to install HD500 edit first.  Open each patch in HD500 edit, and change any input options (like Variax) that aren't available on the HD.  The patches can then be used in the HD.
    Dec 22, 2006
    the 300/400 are completely different animals...
    the 500/pro and desktop can share tones with a little bit of effort.
    this utility can help: http://www.jzab.de/content/pod-hd
  • kdog Just Startin' 34 posts since
    Jan 25, 2007
    It is cool that there are workarounds and it is much appreciated that people are willing to come up with them and contribute them here, but, to be honest, as a long time pod 2.0 and XT user who just recently upgraded to the HD desktop, I am surprised and disappointed that Line 6 has not taken ownership of making auto import work across compatible devices.
    The internal hardware and firmware of the desktop, 500, and pro units are virtually identical and it is absurd that there are three separate editors and a convoluted import process given the value that a seamless import capability would provide to their customers. The 2.0 and XT lines both supported auto import of patches and a unified editor for related hardware and it is disconcerting that Line 6 has not addressed this given that these are no longer newly introduced products and are the mature core of their modeling technology.
    In fact, overall, my first impression of the HD is that the editor/software and firmware are actually not nearly as well thought out or "finished" feeling as the XT was even though the units are up to a 2.x revision... aside from the pretty UI graphics, the entire thing feels like a beta/unfinished product and does not meet the standard Line 6 has set for itself in previous products, which is incredibly disappointing for a long time fan/customer.
    So, really, IMHO, the poster's original question of "why" it is like this, and more importantly, if it will always be like this, should be addressed by L6 since they have clearly overcome this limitation on their legacy units and they are no longer meeting that level of capability with the HD.
  • Ed_Saxman Just Startin' 62 posts since
    Jan 4, 2010
    Just change the file extension. No converter needed for Pod HD desktop/500/Pro patches or setlists. Not tried with entire bundles but it´s probably the same.
      Dec 22, 2006
      not entirely correct...
      if you import a tone from the pro that uses the variax input for exampe that doesn't exist on the desktop... you might find your pod stuck in a reboot loop....
      however, not always the case and you can get away with it....
      you can also simply drag and drop into the location you wish to save the tone without changing the file extension and it will work... but the same potential issue i noted above.
      ***and possibly other issues, after an update or a change here and there...
      the tool changes the tones to avoid this...
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
