117 Views 3 Replies Latest reply: Jan 25, 2013 12:30 PM by hifiman RSS
hifiman Just Startin' 2 posts since
Aug 20, 2012
Jan 24, 2013 11:29 AM
Question about volume on HD500
Please excuse me but I am new to the HD500. Everything is fine except that when I turn it on and go to a preset it often is soft in volume. However as soon as I barely turn the Vol or Master or Drive knobs on the HD500 itself it jumps way up in volume. Any thoughts? Thanks
  • GTLazer Just Startin' 79 posts since
    Jun 7, 2012
    Jan 25, 2013 1:23 AM (in response to hifiman)
    Re: Question about volume on HD500
    This is normal behaviour.
    If you've got a preset where the volume is at, say, 30%, and when you change to that preset your volume knob is in the 80% position, the POD will respond to changes as soon as you start to move the knob. So, if you want to change the volume to about 35%, you'll turn the knob down from the 80% position, initially causing a jump to 79%.
    Does that make sense?
    • spaceatl Expert Line 6 User 4,456 posts since
      Jan 24, 2007
      Jan 25, 2013 5:18 AM (in response to GTLazer)
      +1
      Keep in mind that the Channel Volume is stored and recalled with a preset...The master volume is not...So when you level out your patches, generally you pick one and set a comfortable level on the master...then go through them adjusting and storing only the channel volume...leave the master set...At that point, your patches should level out for you a bit better...
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
