Jan 25, 2013 2:50 PM
HD 500 dual input routing question
Like (0)
I poked through the manual, but couldn't find an easy way to do this.
I want my Electric guitar plugged into Guitar input
I want my acousitc guitar plugged into aux input.
Electric guitar signal should map to XLR output left
Acoustic guitar signal should map to XLR ouput right
I can then run both to a soundboard on different channels. As I change patches, I'd play the appropriate guitar to match, and thus send to the proper channel. This way I don't have to share 1 channel for two I guitars
I probably could do this with some patch level mixer L/R panning shinanigans, but is there a way to do this globally?
...You need to set Guitar 1 into Input 1 and Guitar 2 to Aux on the input setup page...that can saved per patch....Guitar 1 would use Chain A and Aux would use Chain B...basically you just setup a patch becaue you can disable the input in the setup page...you can use global input settings...but then you can to program the mixer to mute which ever instrument you need muted...anyhoo, 6 of 1, half dozen of another...work with the Input setup page and the mixer...
