Jan 28, 2013 7:59 AM
POD HD400 DELAY ISSUE
Like (0)
Greetings,
I want to ask about an issue I'm having with my Pod HD400, when I'm using a delay and setting the level above 80%, my main signal level goes down and the repetition level goes up.
Is this normal?
Thank you for your help.
That sounds normal to me. I think on most of the delays, the setting where the level of the dry and repeated signal are equal to one another is somewhere around 60-75%. It varies model to model, but the level knob for the delays behaves differently than the mix knob for the reverb does. With reverb, the dry level remains the same until the very end of the knob where it gives you 100% wet and 0% dry. The delay level knob starts lowering the dry level earlier on.
