Jan 30, 2013 2:08 AM
I think stagescape M20D is generally a good product. But!
Like (0)
However, the file management (setup and scene) is not practical.
This is to improve.
(The scenes that disappear cause you have a setup change is a bit like if you lost all your files when you modify the root directory.) At a minimum there should be a warning. Not?
Me is always the same backline (my group) I think in songs.
We all used to manipulate files on Mac or Windows and here the interface does not allow all the facilities of its systems' damage.
I think it lacks some sort of file explorer. Not?
Backup (*. Bin) can not see that it contains the name of the scenes? what setup?
Otherwise it is a good product. Improved.![]()
I agree.
We are imrproving the file system behavior and I agree that a more explorer- like file browser would be helpful. The scenes are always a part of a setup because the setup contains the input settings such as which input a channel is assigned to. If you always want to store everything, including the input patch, always save setups. Since you are saying that you always use the same setup just saving this setup should always maintain your scenes.
I have just updated with the new 1.10 firmware and before I did, my unit asked if I wanted to back up so I did. I then installed the 1.10 update and then updated with the backup .bin. All my setups and scenes are there and waiting. So not sure what the original posters point is.
