Jan 30, 2013 2:04 PM
SS WITH ONE SPEAKER ONLY
Like (0)
Is it possibile to connect L6 LINK OUT TO A STANDARD ACTIVE SPEAKER ? ( ex RCA speaker).;
This way i could get L& R OUT TO ONE SPEAKER .
At present I'connecting one speaker to L main out and it seems that I get only left out and not mono out....
Also chorus FX C. doesn' seem to work well with L main out......
I also undestand I wan't be' able to access G EQ but I would get a full mono signal if connection Is possibile
Do NOT connect the L6 LINK OUT to a standard active speaker or simmilar analog device (Amplifier). The L6 Link is a digital signal!
I suppose, that the main out can not be use as mono.
Try to use a Monitor out, if you want to use only one speaker, because the monitor out is mono. (with Firmware Version 1.1 you can make monitor as stereo, but in your case you don't want to)
