207 Views 4 Replies Latest reply: Mar 26, 2013 10:13 AM by enosthas RSS
enosthas Just Startin' 17 posts since
Jul 9, 2009
Feb 5, 2013 12:37 PM
2 M13 together (PRE / POST)
I've been having fun with my m13. And I do feel the difference in sound when connecting to my amp INPUT or FX/LOOP.
Have anyone tryed connecting 2 simultaneous M13. One in front the AMP (INPUT) for Overdrives and Filters
and another one to the FX/LOOP forr Modulations and Delays? So you can get an array of 8 effects.
It sounds I can do that, but in other post there is a comment that in that configuration you only get 2 different sets of 4 simmultaneous effects?
Did I miss something?
Any comment is welcome....! (And By the way its not G.A.S)
  • Beacheshome Just Startin' 14 posts since
    Jan 16, 2009
    Feb 5, 2013 1:20 PM (in response to enosthas)
    Re: 2 M13 together (PRE / POST)
    Yes and yes. You will have an array of  8 simultaneous effects AND 2 different sets of 4 effects. (Same thing). One m13 going direct to the amp input for compression, distortion, eq, filters and wah etc. The other into the effects loop for time based and modulation effects.
  • tyerex Just Startin' 1 posts since
    Oct 31, 2007
    Feb 24, 2013 6:13 PM (in response to enosthas)
    You will definitely notice the difference in sound putting the m13 before your amp's input versus going through your amp's FX loop.
    and unless you need 8 simultaneous effects, you don't need two m13's to acheive what you want. The M13 has an effects loop built in, so you can have 2 effects going to the input of your amp and 2 effects running through your effects loop.
    That's how I use mine live, and it's definitely a noticable improvement putting your time based effects (like delay) in the FX loop of your amp.
    A great way to hear the difference is to setup the M13 using the 4 cable method, and set up two FX switches on the M13 to have the exact same delay setting. If one is going to the input of your amp and the other goes through the FX loop, then you can A/B back and forth to hear the difference in real time.
    That's what sold me on using 4 cables instead of 2.
    I just wish they would make the M9 mono with an FX loop (instead of stereo) so I could have the smaller footprint and still have my delay go through the FX loop.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
