Feb 5, 2013 7:48 PM
I'm having patches jump up in volume intermittently, anybody else?
Like (0)
I've been editing some patches, feeling like I'm mastering this, but every now and then encountering some weirdness. I noticed, while switching back and forth between 2 patches, that every once in a while, one of the patches will suddenly be WAY louder than it was programmed to be. It uses the JCM800 model, don't know if that's significant. Anyone else experience this? If this happens on a gig, it would definitely be very uncool.
The chances are it's a bit of dust or condensation that has crept into the pots on your gear. Keep in mind that the potentiometers on your POD HD and the DT amp work digitally. This means that instead of a bit of dirt in the pot making a scratchy noise (like on analogue gear) a bit of dirt will actually deliver a false resistance value that results in an incorrect digital value for things like volume level.
This is how to fix it...
Periodically, rotate all the pots on your gear a dozen times (or so) through the full range. This will get rid of anything that might lead to a bad resistance value leading to an incorrect digital value. If you're using preset controls on the POD HD, rather than setting them as you go, you can park the pots down on zero. You will notice that the pots have a small null range down near zero and up at 100%, if you park the knobs in the null zones they'll be less succeptable to minute changes in values. If you do this, it should fix the problem for you.
If this doesn't fix the issue there may be a problem with your gear. Give it a go and let us know if it sorts things out for you.
Cheers,
Crusty
This thread might be related to your problem:
