169 Views 5 Replies Latest reply: Feb 13, 2013 11:29 AM by scottyo78 RSS
batatop Just Startin' 10 posts since
Dec 4, 2012
Feb 7, 2013 7:52 AM
Anyone knows how can I get pull me under tone?
I don't know if I can ask tone requests here. But thank you if you can help...
  • meambobbo Iknowathingortwo 1,702 posts since
    Dec 13, 2007
    Feb 7, 2013 8:49 AM (in response to batatop)
    Re: Anyone knows how can I get pull me under tone?
    see here:
    www.foobazaar.com/podhd/patches/
    the list.txt file lists all my patches with detailed descriptions
    click the folder for the pod HD you have to see all the patches.  you'll be most interested in:
    clean:
    CL_DT-Cln
    dirty:
    SH_DT-MkIV
    lead:
    SH_DT-MkII
    Keep in mind these were dialed in for more modern DT tones, but you can get that 80's esque I&W sound by using less bass and more midrange.
    There's also a setlist file in there with all my patches if you like those.  I cover a wide variety of tones, mostly dirty.
      • scottyo78 Just Startin' 114 posts since
        May 29, 2006
        Feb 11, 2013 4:35 PM (in response to batatop)
        Go here and there's 6 pages of Petrucci tones to try.
        No offense at all intended, but I've tried quite a few of Meambobbo's tones and I don't like them. Of course I'm using 2 different (solid state) amps and studio (powered) monitors. So... a "good sounding tone" is subjective and depends on your gear (and a myriad of other things, room size, room dressing, volume, etc).
          Dec 13, 2007
          Feb 11, 2013 5:56 PM (in response to scottyo78)
          no offense taken here - i don't like my patches a lot of the time too, and always seek to improve them.  they've changed a lot over the last 2 years.  most of the ones I last uploaded to customtone have 5 stars, but i've only rarely felt that any of them were perfect.
          i also shouldn't have so crudely said "try this patch".  guitar woods, scale length, setup, string gauge, pickups, and even playing technique affect the tone in front of the pod.  and whatever you connect to, plus your room, etc also matter.  Other people's patches are more likely a starting point than an ending point.  Any pre-eq and gain levels should be tweaked to compensate for the guitar you use.  Any post-EQ (even getting into cab selection) should take into account the monitors/cab being played through, and the room playing in.
          As a case in point, I switched the pickups on my main guitar, and had to change all my patches to compensate.
          according to wikipedia, john used the mesa quad pre-amp on Images and Words.  Having owned one myself, and it basically being a Mark IIC+ and a Mark III in one unit, I really feel like the only amp model/distortion tone that will get this tone is the Uber amp model, but it needs some serious pre-EQ to remove any low-end mud and dial in the right midrange peak to get it to djent like a Mark.  Since I like to use "dual cabs", I don't have enough DSP to add many effects.  I find the Line 6 Drive is the most versatile means of pre-EQ'ing the tone.  With more DSP, I would use the Line 6 Drive plus 1-2 EQ effects.  Then you can really tighten up the low end without making the tone become too thin.
          If anyone knows a better way to get a Mesa Mark tone, I'm all ears.  Here's a sample of an older version of my Mark II patch: http://soundcloud.com/meambobbo/pod-hd500-dt-mkii-tone
          i give more general advice on dialing in tones in my guide: www.foobazaar.com/podhd/toneGuide/  It may help you tweak a patch that gets you close to being perfect.
            May 29, 2006
            Feb 13, 2013 11:29 AM (in response to meambobbo)
            For sure... I've even had to change my patches when I got a new guitar cord!
            Most patches (whereever they come from) are just a starting point for me. Both my amps at home are against a wall with 6 - 8" gap in a carpeted room. If I go into a garage or warehouse (cement & tile) for practice, I simply (and have to) turn down the treble to stay fairly close. I'm too lazy to hang out after and dial patches in, plus my ears are already fatigued from band practice.
            meambobbo wrote:
            ... guitar woods, scale length, setup, string gauge, pickups, and even playing technique affect the tone in front of the pod.  and whatever you connect to, plus your room, etc also matter.  Other people's patches are more likely a starting point than an ending point.  Any pre-eq and gain levels should be tweaked to compensate for the guitar you use.  Any post-EQ (even getting into cab selection) should take into account the monitors/cab being played through, and the room playing in.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
