Feb 9, 2013 12:53 PM
HD500; change in tone, dropped lows, mids!
Like (0)
Hi all,
Rather recently (a few months ago), I bought my unit, the HD 500. I use it mainly during live sessions, and my current setup is direct from the balance out (XLR) to mixer, and listening via monitors. Two weeks, suddenly noticed a total drop of lows and mids from the output, only the highs, so all I hear from the monitors is trebly, crackly sound and not the powerful crunchy sound that I am used to . The only change I could think of was that I used an RCD to protect all my gear, but no changes on the mixer, or the monitor EQs, or on the POD.
Any advice? Am I missing something? A few days ago, I also upgraded to the latest firmware, but still the problem remains.
Any advice would be highly appreciated.
Thanks.
Kind regards.
Ben
Ben
If you have flashed the firmware you could try a global settings reset. Hold down the 'left' button on the directional keypad and power up the Pod. This does a global settings reset and can occasionally help. It is also useful if the preset you were working with was corrupt as it jumps you back to patch 1A. If you use this, you will need to check your global settings to make sure they are how you want them. You will also need to recalibrate your expression pedal (details here --> http://line6.com/support/docs/DOC-2223). None of your homemade presets will be lost but your setlist names will be renamed to the default names.
Frankly though, it sounds more like a cable/connection issue to me. Suggest:
1) Try different XLR cables/inputs on the mixer.
2) Try it with the 1/4" Outputs ... any better? Again, consider cables and connectors.
I'd second checking the cables first including the one you use on your guitar.
Hi all,
Thanks for the replies, I did a hard reset just sometime ago, will post as soon as I am able to check if the reset works.
- 1/4" cables are all good, brand new Vovox, and Monster cables... so hardly suspect cables!
- Same with the XLR cables.
Kind regards.
Ben
