Feb 14, 2013 12:29 PM
just got a x3.
Like (0)
i try to dl new amps and cabs, but it says in gearbox i need to update the firmware of the pod. how?
download monkey, and it will help you update everything else.
all updates are done, says needs 2.0 or higher
there are no "new amps and cabs" to download if all updates are done... all are buit into the x3...
what exactly are you trying to do when you see this message?
loading a coulpe of patch i dl'd from the site
then the issue is likely a known bug... i'm guessing those tones do not have cabs enabled.
either add cabs, or don't use those tones.
and how do i add cabs?
use gearbox, before you try to send it to the x3.
here's a thread where the user figured this out: http://line6.com/support/message/161422#161422
i've never had the issue myself... i've just read about it... hopefully that helps.
