125 Views 4 Replies Latest reply: Feb 17, 2013 2:27 AM by KevinTJH RSS
Yeli Just Startin' 3 posts since
Feb 16, 2013
Feb 16, 2013 11:18 AM
How to record dry sound of guitar with POD Farm 2 in FL Studio?
Hey there!
Was looking for such topic, which are many but no real solution was found.
So, I'm using a POD Farm 2 and FL Studio 10 which are good. But the problem is: I cannot record my guitar CLEAN while it is having a POD Farm effect hanging on a channel, which I record thru. It just comes out that the recorded file is already effected by an effect and not a dry sound which could be changed later. So that makes it useless to me cuz I want to experiment with the tone, that's why I bought it.
I found one solution aforementioned - to use Edison recorder BEFORE the POD effect, so it would record the clean sound. That looks logical, but it comes out that the sound get much WEAKER, not like it sounds, no matter how I effect it later. So, is there any real solution to make a powerful fry sound which can be 100% copy the one which it did sound like while recording?
thanx a lot!
  • dback Just Startin' 20 posts since
    Aug 30, 2010
    I'm not familiar with FL Studio, but here's the way that I record a clean guitar with Logic Pro.
    1.  Make sure you have Pod Farm open from the standalone version.
    2.  Go to the mixer view in the stand alone version and select your outputs to be "Dry".  Also, as a double-check, be sure to check that the input is set for "Instrument".
    3.  Set your tones, so you hear a "wet" version through your monitors.
    4.  In your DAW (In your case FL Studio), arm your track to record and Mute the track so you don't hear it through the DAW (Thus the reason for using the standalone Pod Farm).
    5.  Record.
    You should be recording a "dry" track.  Upon playback, you can then insert Pod Farm as a plug-in, and then modify the clean track recording with the amp sounds.
    Reply back if it works or if you have any othe issues!
    DBack
    http://www.facebook.com/doughnutblonde
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
