286 Views 5 Replies Latest reply: Mar 6, 2013 9:16 PM by davidb7170 RSS
alory1995 Just Startin' 2 posts since
May 25, 2012
Feb 22, 2013 6:50 PM
is it possible to replace the pickup on 69?
I found myself not so happy about the humbucker on the 69 because it's not so hot as the Seymour Duncan JB which i got used to  (for some hard rock and metal playing) so is it possible to replace the humbucker with out damaging the modeling system while keeping a balanced level?
  • Currently Being Moderated
    Feb 22, 2013 10:47 PM (in response to alory1995)
    Re: is it possible to replace the pickup on 69?
    I haven't done it by myself, but others have succesfully done it. You can find some answers here:
    http://line6.com/support/thread/81001
    http://line6.com/support/thread/55449
    Crusty_Old_Rocker has good point in one of this topics: The magnetic pickups feed into the digital circuitry so that the audio signal can travel through the VDI cable.  This means that if you put in a pickup that is too "hot" it could result in clipping within the Variax circuitry.  You would want to be sure that the impedance and output of the pickups are comparible to what's already in there otherwise the levels could be all out of whack even if there isn't any clipping.
    Also, there is wiring diagram for all JTV's in case you've missed it:
    http://line6.com/support/docs/DOC-2496
    • toasterdude Just Startin' 745 posts since
      Oct 23, 2006
      Mar 5, 2013 4:41 AM (in response to JanKupsa)
      I am bringing in my 69 to my tech for some more tweaks including swapping all the pickups. I have duncan p rails on my xplants and have had no issues. In fact normally the modeled sound is way hotter than mags sound. I am putting duncan prails in the bridge and neck and probably a lipstick tube in the middle.
      Once I do that I will have an extra LPB body, JTV 69 neck and the original pickups. Basically a "gutless" JTV 69.
      • davidb7170 Just Startin' 253 posts since
        May 3, 2008
        Mar 6, 2013 9:16 PM (in response to toasterdude)
        I bought my 59 in 10/2010, got it in 5/2011 -- bumps along the way -- switch issue, but fixed. Saw no reason to change its pups --  they sound very good as they are. Bought another JTV in 10/2012 -- this time a 69S -- 3 single coil pups. Liked the way they sounded except for the single coil hum. I've been a Fender guy and know that's what to expect with SC's, but got spoiled by my LP and the JTV59 humbuckers... So I bought & installed a set of DiMarzio noiseless SC's -- the Injector Bridge, Area 67 middle, & Injector Neck. The install was kind of a pain -- lotsa wires and short leads etc, but I did it fine -- look at the wiring diagram of the new pups versus the L6 document mentioned above.
        The new ones sound very good - have some more output the than the L6 originals, but are quiet as a church as far as hum goes -- even quieter than the HB's I have in the 59, my LP, and my 1973 Fender Tele Deluxe -- way quieter than my Strat. I really had no issues with the 69S's original pups' tones, besides the SC hum... Had to change the DiMarzio's cover from white to the mint green color of the L6 face plate & pups on the gold 69S, but that was like $10. Did it after living with the ones that came on the replacements for a couple of weeks, so had to open the guitar up again to do it, but was no big deal. Worst part was dealing with the trem bridge coming unhinged when the strings were removed to take off the front plate to get at the guts. I did ithe pickup swap in January -- not quite 2 months from receiving the guitar. The guitar's been a champ all along.
        I know you're talking about the regular 69's HB, but you will probably run into some of the same stuff under the hood that I did. The only replacement I would worry about the pickup levels would be active pups, like EMG's etc that you would need to power with a 9 volt battery, If your target pup is passive, it should not be an issue. The guts are the same in all of the JTV's, as far as I've heard, and the 89's pups are supposed to hotter than the 69 & 59 HB's. From what I recall of discussions here, the 59 HB is hotter than the 69 HB, as they were trying to keep levels somewhat balanced between the 69's HB and SC pups on the same guitar, I'm not an authority on that, just recall it sometime ago coming up in the forums...
        They had 3 different versions of the pickups for the 3 JTV's that they had funny code names so they could distinguish which went with what model -- Kirk was the 69, and then there was Bones (59) & Spock (89) -- Star Trek references. When I pulled my SC's out of the 69, they are marked Kirk-B, Kirk-M, and Kirk-N (Bridge, Middle, Neck)... Apparently they still are following that....
        For what it's worth -- my 2 cents...
        Dave
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
