168 Views 2 Replies Latest reply: Mar 6, 2013 11:21 AM by robmartino RSS
robmartino Just Startin' 9 posts since
Oct 12, 2010
Mar 5, 2013 9:16 AM
Considering StageSource L2t for solo gigs
Hi all,
For the past couple years I've been using a POD HD500 and Fishman SA220 Soloamp for all my solo Chapman Stick gigs, which generally has been a nice setup but there are times I wish I had a bit more low end (the Fishman rolls off below 80Hz and is prone to occassional cabinet rattle at higher volumes).  I've been looking at the L2t as another lightweight option that can function as a PA behind me in small spaces or a monitor at larger venues when I can plug into a bigger house system.  It also seems ideal if I later want to add an L2m for a stereo setup.
I typically play for small crowds, say in the 20-100 range, so I don't need a ton of volume, but solid presence and wide sound field along the whole frequency range is important (my lowest note is a bass E, but since it's solo music, I'm after a more balanced sound rather than providing heavy bass, perhaps equivalent to a keyboard).  The L2t looks like it will go lower than the Fishman but I wanted to see if anyone has tried one of these with a full range instrument like a keyboard setup.
One nice aspect of the Fishman is that I can just plug straight in the two channels (bass and treble are separate pickups) if I don't want effects, and use the built-in EQ and reverb.  The L2t seems to offer similar functionality although I notice the input impedance is a lot lower if I'm reading the specs correctly (2.63 kΩ vs. the Fishman's 10 MΩ), would that not be ideal for passive electric pickups?
Thanks,
Rob
http://robmartino.com
  • dboomer Line 6 Support 1,997 posts since
    Oct 13, 2008
    Mar 6, 2013 9:51 AM (in response to robmartino)
    Re: Considering StageSource L2t for solo gigs
    Hey Rob
    Input impedance is always a trade-off between "tone" and "noise".  Too high and it's noisy, too low and you lose a little bass response.  No matter what you do you will suffer a little of both (nothing is perfect).  Generally you'd like to shoot for a 10:1 ratio between the output impedance of the instrument and the input impedance of the preamp.  But you are still OK at 1:1.
    The 2k input is for balanced mic inputs.  The 1/4" jack has an input impedance of 100k which should be just fine for nearly every passive magnetic pickup out there.  It's also fine for the output from instruments with a built-in preamp and for things like synths and drum machines.  It could make a slight tonal change  to some piezo pickups as they have very high capacative outputs.  But remember ... the variax modeling is built-in and that should far surpass the sound quality from piezo pickups anyway.
