157 Views 5 Replies Latest reply: Mar 9, 2013 2:21 PM by johnlockie RSS
johnlockie Just Startin' 4 posts since
Mar 6, 2013
Mar 6, 2013 10:51 PM
Very strange problem w/ Spider Valve 212....
Help!
The best amp I have ever owned appears to have died (partially)....
In the middle of rehearsal the volume just died off, and the LED screen on my amp and foot pedal showed a lot of weird symbols and stuff.
I power cycled my gear, and when it comes back the LED screen on the amp shows this.
I did basic troubleshooting of fuses, connections, and what not....no luck.
Does anyone have any suggestions?  I also tried the factor reset, but that does nothing.  In fact, none of hte amp lights work except the blue power indicator and the LED screen.  I am worried something expensive broke :'-(
  • spaceatl Expert Line 6 User 4,456 posts since
    Jan 24, 2007
    Mar 7, 2013 4:24 AM (in response to johnlockie)
    Re: Very strange problem w/ Spider Valve 212....
    check this out...you have the Blck Boxes of Death...
    http://line6.com/support/message/415388?tstart=0#415388
      • mtnman82 Just Startin' 162 posts since
        Mar 15, 2008
        Mar 9, 2013 10:14 AM (in response to johnlockie)
        Yep, a couple surprisingly serious issues on these amps - the lack of regulator de-rating (and hence dying) on the effects/preamp board and the over sensitivity to dirty power (which is everywhere).  If the black boxes is the regulator thing, your direct out will die as the direct out comes off the preamp board.  A ~$10 part plus heatsink and an hour of technician time should make it better than new.  Only thing we can do for the over sensativity to line power is to lug around a voltage stabilizer.
        I've only had the amp cut out on me once (on an oncore no less...), but suspect it was the power - been using a voltage stabilizer since and it hasn't happenned again.  If that regulator ever goes on mine, I'll replace it with a beefier one and install a heat sink.  I did some looking but couldn't find it - maybe someone else here can - but someone actually did a little write-up on here with pics on replacing the voltage regulator.  If you take it to a shop, I' d print that out and take it with.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
