39 Views 1 Reply Latest reply: Mar 8, 2013 11:32 AM by Mr_Arkadin RSS
connor4695 Just Startin' 1 posts since
Mar 8, 2013
Mar 8, 2013 9:59 AM
Difference bettween Pod Pro and Pod XT Pro?
I am setting up a rack setup. I cannot afford the Pod HD Pro so I have been looking at the Pod Pro and the Pod XT Pro. What are the main differrences between the two devices? Can I get the same tones out of each? I am trying to a get a metal/hardcore tone out of it.
  • Mr_Arkadin Expert Line 6 User 2,379 posts since
    Jan 25, 2007
    Mar 8, 2013 11:32 AM (in response to connor4695)
    Re: Difference bettween Pod Pro and Pod XT Pro?
    Personally I would forget the POD Pro. I always thought the POD 2.0/Pro sound was a little distant - not good for upfront metal.
    So I would say your choices second-hand are either a POD XT Pro with Metal Shop expansion or the POD X3 Pro (which includes the Metal Shop as standard). The XT/X3 share the same basic sound engine - the 2.0/Pro is older.
    If you decide to get the POD XT Pro with Metal Shop already installed make sure the owner can 'gift' the Metal Shop from his account to your account. Otherwise it is tied to his account and the firt time you use Monkey to update or reflash it will look at your account, see no Metal Shop and delete the use of it from your POD XT Pro! Of course if you never run the License Manager or Monkey the expansion pack will remain unaffected.
    So just see which works out more cost-effective. The XT is 2U and the X3 is 3U which may also be a factor.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
