4212 Views 3 Replies Latest reply: Jun 7, 2009 8:38 PM by PsicraftTony RSS
chanjcw Just Startin' 4 posts since
Dec 31, 2008
Jun 5, 2009 12:52 PM
PocketPOD not hooking up to the computer. help!
i just downloaded the Vyzex Pocket POD program and every time i connect the USB from the pocketPOD to the computer, the compuer doesn't even do anything.its not picking up the pocketPOD and it says that theres no midi ports. i have Windows XP. please help!!!!
  • jangrenner Just Startin' 1 posts since
    Jun 4, 2009
    Jun 6, 2009 2:19 PM (in response to chanjcw)
    Re: PocketPOD not hooking up to the computer. help!
    Hi there,
    I just had the same problem. It is solved thanks to the the Vyzeck Troubleshooting guide you can find in this forum : http://line6.com/community/docs/DOC-1382
    It explains the issue of not detecting the pocket pod; it has something to do with some other devices that you have previousely installed and that also use(d) USB. I am not a tech expert, so I just followed the steps in this guide (pdf file), where you have to delete certain registry settings (an "LVUSBSTA"- entry with upper and lower filters).
    After I did that, without reboot, I first disconnected the pocket pod USB cable, deleted the entries in my hardware list in the windows system configuration, replugged the USB cable, startede the Vyzeck, and it worked.
      • PsicraftTony Iknowathingortwo 243 posts since
        Jun 22, 2007
        Jun 7, 2009 8:38 PM (in response to chanjcw)
        Hi Chan,
        The troubleshooting guide should be read carefully to be sure that you are applying the correct solution to the problem at hand. To recap, there are two main issues dealt with in the guide:
        1. USB device driver conflicts: Typically these are caused by webcams and other USB peripherals, notably by Logitech, but also by other third party hardware manufacturers. In the most common conflict case, the registry modifications to clear upper filters solves logitech driver conflicts, but these are precise instructions you shouldn't be improvising on.
        2. Device limit issues: If your Windows computer is overloaded with MIDI device instances, clearing out ghosted items can help get your Pocket POD recognized. After driver conflicts, this is the second most likely cause of your Pocket POD not being seen by your computer.
        All of this said, the first thing I always recommend is to try your Pocket POD on all USB ports first, and then on another computer before you start editing your registry. It could be that your computers USB ports are not compatible with Pocket POD (remotely possible), or that your Pocket POD has a problem with its USB port hardware (unlikely but worth checking out).
        Please check out these options and post back here. We'll go from there.
        Tony
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
