Delay/reverb Spill-over
patch switching
Best Answer TheRealZap , 17 June 2013 - 08:24 AM
Not really... if you turn off delay within the same patch they stay... but if you change patches... no dice, unless you are using the fx loop you suggested.
Go to the full post
2 replies to this topic
#1 joemama78
joemama78
  • 24 posts
  • Registered Products:1
Posted 17 June 2013 - 08:00 AM
I use a lot of delay and reverb and when I switch patches between songs, the trailing signal just gets cut off abruptly. Is there any way to let the decay finish out (spill-over) even after switching to a new patch? I would prefer not to have to hook up an external delay in the fx loop.
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 17 June 2013 - 08:24 AM   Best Answer
#3 bpapina
bpapina
  • 29 posts
  • Registered Products:3
Posted 17 June 2013 - 07:42 PM
I use the Line 6 M5 in the loop and typically set it up for delays. Works great and also will switch (or not) via MIDI when I make patch changes.
Also tagged with one or more of these keywords: patch switching
