RichG Posted October 23, 2014 Share Posted October 23, 2014 The manuals state the following: XD-V70: 9 Vdc, 350mA XD-V75: 9 Vdc, 500mA I'm wondering what the acceptable voltage range is for the input. Can I use a 12 Vdc supply? Quote Link to comment Share on other sites More sharing options...
dboomer Posted October 23, 2014 Share Posted October 23, 2014 +/- 10% is usually safe. Quote Link to comment Share on other sites More sharing options...
RichG Posted October 24, 2014 Author Share Posted October 24, 2014 Hmm... I was looking for a more definitive range other than +/- 10%. For example, from manual specifications: Sennheiser EW100: 10.5 to 16 Vdc Shure SLX: 12 to 18 Vdc Reason I ask is because I'd like to get one adapter and to power 6 XD-V70 receivers. This ( http://www.amazon.com/gp/product/B003TUMDWG ) low cost 12 Vdc, 6A adapter will work as long as the receivers will accept 12 Vdc. Quote Link to comment Share on other sites More sharing options...
dboomer Posted October 24, 2014 Share Posted October 24, 2014 Officially Line 6 would not recommend using any power supply that would provide voltage above 9.9 Vdc. Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted June 17, 2015 Share Posted June 17, 2015 Does such a power supply exist? I've just grabbed a second XD-V75 and likewise, would prefer to power both receivers from a single outlet. Quote Link to comment Share on other sites More sharing options...
Sheriton Posted June 18, 2015 Share Posted June 18, 2015 Does such a power supply exist? Yep - the Line6 XD-AD8. Which also happens to function as an eight way antenna distro too ;) Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted June 18, 2015 Share Posted June 18, 2015 A full on 1U rack size unit is a little overkill for powering just two receivers, and I've no plans to increase the number beyond two. I'm attempting to rationalise and reduce physical connections and equipment rather than increase ;-) but thanks for the suggestion. I've managed to find a 1A 9V centre negative power supply so will give it a try. Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted June 19, 2015 Share Posted June 19, 2015 1A 9V centre negative power supply arrived today: very tidy, even comes with a self adhesive velco strip, so it dropped very neatly into the inside of my gator case, velcrod to the sidewall. Standard plug and figure 8 (iec c7) mains connector so easy to shorten to a sensible few inches in legth without damaging the power supply. Interestingly (and brilliant for rack usage, the 9V side only has 9-12" of cable before the 9V plug, so again, no excess cable to wrap away. Dropped in perfectly, powered up both units perfectly and jobs a good un! Diago PS10 Micropower9 http://www.diago.co.uk/pedal-power/diago-micropower9.html Quote Link to comment Share on other sites More sharing options...
