lolballz Posted November 3, 2014 Share Posted November 3, 2014 So I'm trying to use two guitars simultaneous through the HD500x.I've got a preset that I want to use. The problem is that I want one guitar panned hard left and one hard right, and I can't figure out how to do it. I want to be using the same preset with both my guitars. If I pan either path A or B to let's say right, BOTH the guitars gets panned right and vice versa. I'm using the Guitar and Aux inputs. I'll attach a screenshot of the mixer block settings. Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted November 3, 2014 Share Posted November 3, 2014 Screen shot doesn't show up but what I do to make this work is: Input 1 = Guitar Input 2 = Aux Configure signal chain so there are two independent paths, A & B, each starting at only 1 of the inputs (A to input 1 and B to input 2) and ending at the mixer. The two signal paths come together only after the mixer. In the mixer pan A/B hard L/R respectively. Put no FX after the mixer (or if you do, be sure they're stereo). Now you should have Guitar only coming out L and Aux only coming out L. Quote Link to comment Share on other sites More sharing options...
