Dazzer40 Posted November 15, 2014 Share Posted November 15, 2014 Just some advise on the hd500x I am not using an amp with it would it be ok to plug it straight in the my mix and PA, and also which cable should I use to the mixer Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted November 16, 2014 Share Posted November 16, 2014 I do this all the time but only connect the left XLR to the mixer . I know I lose the right channel but I don't attempt to utilize stereo and what I don't hear doesn't seem to bother me. Everything sounds great. Quote Link to comment Share on other sites More sharing options...
Palico Posted November 17, 2014 Share Posted November 17, 2014 1) a single normal 1/4 jack cable (for a mixed to mono chain signal) 2) two 1/4 jack cables (one for the stereo Left side and one for the Right one) 3) two XLR balanced cables (same results of point 2 above, good solution for long distance connections) On the mixer itself. (assuming your PA setup is setup for Stereo) For 1 use any channel. using a Line In plug. For 2 you can use two difference channels and pan one hard left and one hard right. Or use a stereo channel on the mixer, IMO the best solution if you have a available stereo channel available and cord length is not a problem. For 3 same use two pre-amped channels running hard left and hard right. On 2 & 3 the input will be rather hot so careful not to overdrive the preamps. Quote Link to comment Share on other sites More sharing options...
