Checker1 Posted November 18, 2014 Share Posted November 18, 2014 Is seems to be that the pre delay from the octo reverb is wrong programmed. If you select 200m s pre delay you will hae nearly zero, if you select 0 ms you will get 200ms. I checked that with a scope. Is is only the octo reverb with this fault. (Flash version 2.32) Quote Link to comment Share on other sites More sharing options...
