Empyre Posted November 19, 2014 Share Posted November 19, 2014 I’m using a HD500x with a JTV-59. Both inputs are set to Variax. Has anyone noticed something similar to this: Using a patch with dual amps. Uncheck the button for either amp or even set one of the amps to “---“ so there is one active amp and the other amp is off/bypassed. Can anyone detect an underlying dull tone being played along with the amp still in use's tone? Almost sounds as if you have a dull Reso guitar being played quietly as well as whatever else you actually have dialled in. As soon as I activate a second amp that dull ghost tone goes away. Just in case anyone suggests it: No, I don't think its coming from the magnetic pickups. Quote Link to comment Share on other sites More sharing options...
chuberto Posted November 19, 2014 Share Posted November 19, 2014 What's the amp that you're deactivating bypass volume set at? If set at anything over zero, you'll be getting clean guitar in parallel to your other amp block. Quote Link to comment Share on other sites More sharing options...
