Pod /Drive pedals/ Blackstar /Help
guilhordas
I own a blackstar, 2 drive pedals and a pod hd 500x, I intend not to use the pod as simulator, just like modulation and effects, you guys really think I need to run the pod to blackstar loop or should I run on in the blackstar, remembering that Im not using pod pre amps pod, only effects. 4cm seems to me very hard work to do live, I want to use pod like a pedal
thanksĀ
If you are only using the 500 for delays, modulations, reverbs, etc., it should work very nicely in the loop but pay special attention to if the FX are mono or stereo. You won't get the full effect of some of the stereo FX. You would have to send the other output to another amp to get the full stereo sound. Try to keep all the gain FX like compression and overdrive pedals in front of the preamp. Short answer? It will work but limited.
