alainL Posted December 2, 2014 Share Posted December 2, 2014 Hi to all, I own a Pod GX since 4 years and I've always wondering about input level (stand alone version of PF). I know that there is no way to adjust the input level of PF stand alone compare to the plugin version. In fact, I was wondering if my device has been defective since I bought it. I use a strat and my input level is somewhat a 25% of the input level (see attached picture) when I play the loudest. Do you experience the same? or it is the normal input level. To get decent level, I have to put a compressor as a first effect in chain set with unity compression and adjust the level as desired. Thanks for your feedback. P.S: I've already posted this request a few years ago, the answer was about the way that the device calibration it is, but i'm not convinced these days... Quote Link to comment Share on other sites More sharing options...
jjRocker Posted December 2, 2014 Share Posted December 2, 2014 I think it´s like it should be.I have a Toneport DI and the input looks the same when using a guitar with singlecoils. It all depends how strong your guitar signal is.When using vintage singlecoils or humbuckers the output of your guitar isn´t as strong as with modern pickups.The pickup height also influences your output.I use a strat with Fender 57/62 pickups in neck & mid position and I´ve set the pickup height very low so input level was even lower than yours. I also put a compressor or a TS (gain at 0) in front of a clean amp to boost the inut. I´m also curious what others do. Quote Link to comment Share on other sites More sharing options...
alainL Posted December 2, 2014 Author Share Posted December 2, 2014 Thanks for the feedback. So, it is the way it is. Case closed! I wish the stand alone version had an input volume control like the plugins or maybe input level control at the driver stage. Anyway, will not be a very big deal since i'm buying a tube preamp for my condenser mic (Presonus or TubeMP). So I will use it as well for my instrument to level up the gain slightly. Actually what I really like with the GX and PF is the Tone Direct feature. Not that I have a lot of latency in plugin mode, but when you record with headphones, it pays to have 0ms latency. Quote Link to comment Share on other sites More sharing options...
