Can I manage ( rearrange) the pre-stored amp models in DT50? FW 2.0
Andrioman
Hey! Is there a way to manage,rearrange and save the models in DT 50? Can I change some model topology,Class etc. and save it to one of the 4 positions of each channel?
Also,exactly which 8 models are located to the 8 positions in the new 2.0 FW?
Thanks! :-)
Thanks! :-)
You can do all of that with a 3rd party editor connected by midi to your DT.  The editors can be found at the link below.  Once you get connected you can see what is there and change everything to suit your taste including amp models, cabs, configuration, and reverb.
http://line6.com/support/topic/124-user-created-dt-editors/
Hey! Thanks for the answer! I have ''DT Edit'' software installed,I use it without any problems,but there is no function to save my changes to DT50 amp. The "DT Customizer" software looks nice,but it's not on the app store anymore and is not possible to download it!
Am I missing something?
OK,I just made a test and the settings are present after the power ON-OFF procedure! Cool! Thanks for the advice! That's all I need! Cheers man! :-)
So are you saying that when you use DT Edit, that when you make changes to everything like EQ, channel volume, etc. that it stores on the amp and all you have to do is change the topology mode and channel number to recall all of your settings?
no... will not save EQ. drive, channel vol etc....
will only save amp models and amp specific settings that you change....
anything you can dial in on the front... is not saved.....
it will always use the settings of the actual knobs... nothing saved.
