folante Posted December 4, 2014 Share Posted December 4, 2014 Hi everybody, I am currently use the distortion effects on a real amplificator clean channel without POD XT Live amp simulations. But I am looking for a different type of distortion that there is not on the POD effects. So I wish to ask if someone of you use the amp simulation in a combination with a distortion effect in a front input real amplificator. And in a live situation too. Thanks in advance !!! Quote Link to comment Share on other sites More sharing options...
BillBee Posted December 4, 2014 Share Posted December 4, 2014 Hey there my man and welcome to the forums! I can partially help - years ago I tried it and it can sound pretty good. Setting wise you are going to have to flip on the PAD (IIRC) and have a look at the noise gate as you will be sending in a boosted feed. Keep in mind you will need to set up your amp sim to be pretty clean unless you are wanting to stack gain - which can get pretty noisey. A clean boost pedal in front can help with lower distortion mild type breakup if that's what you are after. Live? nope defeated why I had the XTL which was to simplify setup and travel - bought the Metal Pack and loved it. -Bill Quote Link to comment Share on other sites More sharing options...
folante Posted December 4, 2014 Author Share Posted December 4, 2014 Thanks Bill for the answer !!! Just a few explanation ... what do you mean with "have to flip on the PAD (IIRC)"? And what is the "XTL"? In my thoughts I would like to set up an overdrive amp simulator that enters in the real amplifier set to a clean channel. Then I would use a distortion stomp to increase gain and volume. Do you think is realizable? Thanks again, bye !!! Quote Link to comment Share on other sites More sharing options...
BillBee Posted December 4, 2014 Share Posted December 4, 2014 XTL = XT Live :) There is a little switch labeled PAD which will lower a high signal input a bit. Like if you are running EMGs the input signal might start clipping and causing issues with the tones. Like too much distortion, etc.. I don't see any flaws in your plan, the pedal will hit the chain in front just like the XTL's preamp would. Just start low volume/gain and gradually increase it. If memory serves me correctly I used a Tubescreamer Clone and it was pretty good. -Bill Quote Link to comment Share on other sites More sharing options...
