Interesting Info On Pickups
joel_brown
I read this on Wikipedia while trying to learn more about pickup resistance/impedance.  I thought others might find this interesting.   Magnetic pickups[edit]
A magnetic pickup consists of a permanent magnet with a core of material such as alnico or ceramic, wrapped with a coil of several thousand turns of fine enameled copper wire. The pickup is most often mounted on the body of the instrument, but can be attached to the bridge, neck or pickguard, as on many electro-acoustic archtop jazz guitars and string basses. The permanent magnet creates a magnetic field; the motion of the vibrating steel strings disturbs the field, and the changing magnetic flux induces a voltage in the coil. This signal is then carried to amplification or recording equipment via a cable. There may also be an internal preamplifier stage between the pickup and cable.
Output[edit]
The output voltage of magnetic pickups varies between 100 mV rms to over 1 V rms for some of the higher output types.[citation needed] A hard strum on all 6 guitar strings can produce a larger output voltage swing, typically peak voltages of +/- 5 volts for single coil pickups and +/- 10 volt peaks on dual coil pickups.[citation needed] Some high-output pickups achieve this by employing very strong magnets, thus creating more flux and thereby more output. This can be detrimental to the final sound because the magnet's pull on the strings can cause problems with intonation as well as damp the strings and reduce sustain. Other high-output pickups have more turns of wire to increase the voltage generated by the string's movement. However, this also increases the pickup's output resistance/impedance, which can affect high frequencies if the pickup is not isolated by a buffer amplifier or a DI unit.
Pickup sound[edit]
Single coil pickups, Fender Stratocaster (1963)
The turns of wire in proximity to each other have an equivalent self-capacitance that, when added to any cable capacitance present, resonates with the inductance of the winding. This resonance can accentuate certain frequencies, giving the pickup a characteristic tonal quality. The more turns of wire in the winding, the higher the output voltage but the lower this resonance frequency. The inductive source impedance inherent in this type of transducer makes it less linear than other forms of pickups,[citation needed] such as piezo-electric or optical. The tonal quality produced by this nonlinearity is, however, subject to taste, and some guitarists and luthiers consider it aesthetically superior to a more linear transducer.[citation needed]
The external load usually consists of resistance (the volume and tone potentiometer in the guitar, and any resistance to ground at the amplifier input) and capacitance between the hot lead and shield in the guitar cable. The electric cable also has a capacitance, which can be a significant portion of the overall system capacitance. This arrangement of passive components forms a resistively-damped second-order low-pass filter. Pickups are usually designed to feed a high input impedance, typically a megohm or more, and a low impedance load reduces the high-frequency response of the pickup because of the filtering effect of the inductance.
Humbuckers[edit]
Main article: Humbucker
PRS's Dragon humbucker
Single coil pickups act like a directional antenna and are prone to pick up mains hum (nuisance electromagnetic interference generated by electrical power cables, power transformers, and fluorescent light ballasts in the area) along with the musical signal. Mains hum consists of a fundamental signal at a nominal 50 or 60 Hz, depending on local alternating current frequency, and usually some harmonic content. The changing magnetic flux caused by the mains current links with the windings of the pickup, inducing a voltage by transformer action. The pickups also are sensitive to the electromagnetic field from nearby cathode ray tubes in video monitors or televisions.
To overcome this effect, the humbucking pickup was invented by Joseph Raymond "Ray" Butts, but Seth Lover of Gibson was also working on one himself. Ray Butts initially developed one on his own and later worked with Gretsch.[1] Who developed it first is a matter of some debate, but Ray Butts was awarded the first patent (U.S. Patent 2,892,371) and Seth Lover came next (U.S. Patent 2,896,491). Ultimately, both men developed essentially the same concept, but Ray Butts was never recognized as the one who produced it first.
A humbucking pickup, shown in the image on the right, is composed of two coils. Each coil is wound reverse to one another. However, the six magnetic poles are opposite in polarity in each winding. Since ambient hum from power-supply transformers, radio frequencies, or electrical devices reaches the coils as common-mode noise, it induces an electrical current of equal magnitude in each coil. Because the windings are reversed in each pickup coil, the electro-magnetic interference sine wave signals in each pickup are equal and in antiphase, resulting in them canceling each other. However, the signal from the guitar string is doubled, due to the phase reversal caused by the out of phase magnets. The magnets being out of phase in conjunction with the coil windings being out of phase put the guitar string signal from each pickup in phase with one another. Therefore, the voltage of the signal is approximately doubled, if the two coils are connected in series.
When wired in series, as is most common, the overall inductance of the pickup is increased, which lowers its resonance frequency and attenuates the higher frequencies, giving a less trebly tone (i.e., "fatter") than either of the two component single-coil pickups would give alone. Because the two coils are wired in series, the resulting signal that is output by the pickup is larger in amplitude, thus more able to overdrive the early stages of the amplifier.
An alternative wiring places the coils in buck parallel. The equal common-mode mains hum interference cancels, while the string variation signal sums. This method has a more neutral effect on resonant frequency: mutual capacitance is doubled (which if inductance were constant would lower the resonant frequency), and inductance is halved (which would raise the resonant frequency without the capacitance change). The net is no change in resonant frequency. This pickup wiring is rare,[2] as guitarists have come to expect that humbucking 'has a sound', and is not neutral. On fine jazz guitars, the parallel wiring produces significantly cleaner sound,[2] as the lowered source impedance drives capacitive cable with lower high frequency attenuation.
A side-by-side humbucking pickup senses a wider section of the string (has a wider aperture) than a single-coil pickup. This affects tone.[3] By picking up a larger portion of the vibrating string more lower harmonics are present in the signal produced by the pickup in relation to high harmonics, resulting in a "fatter" tone. Humbucking pickups in the narrow form factor of a single coil, designed to replace single-coil pickups, have the narrower aperture resembling that of a single coil pickup. Some models of these single-coil-replacement humbuckers produce more authentic resemblances to classic single coil tones than full-size humbucking pickups of a similar inductance, which shows that the amount of high-frequency rolloff due to coil inductance is not the only factor in that sound.
