Multi Cab Question
Best Answer spaceatl , 22 June 2013 - 10:10 AM
right...the combo gets half the power and the cab gets the other half...where the combo speaker gets around 12 watts, each speakers in the cab is seeing around 4-5 watts...
You would likely get a bit better cone volume match if you changed the combo to a 16 ohm speaker...parallel combined load with your 8 ohm cab is about 5.3 ohms...no problem on the 4 ohm tap. I have been running my SV MK1, MK2, DT50 and DT25 with a 5.3 ohm load for years...however, I do it but using a 212 cab loaded with 16 ohm speakers...all my 112 combos have 16 ohm speakers...Three 16 ohm speakers in parallel is 5.3 ohms...cone volume is balanced...In your case, a 16 ohm speaker with an SPL rating that is -3db less than Vintage 30s would likely get pretty close...
Go to the full post
1 reply to this topic
#1 Melissiah
Melissiah
    Iknowathingortwo
  • PipPip
  • 125 posts
  • LocationQuébec
  • Registered Products:4
Posted 21 June 2013 - 11:41 AM
Hi
DT25 combo
I also have a mesa 4x12 vintage 30 closed back 8ohms
I like the sound of DT25 alone, I like the sound of recto alone and I like the sound of boths using the 2 4ohms jack.
Is it stupid doing this?
It's 4 speakers against 1 per output
Does the speaker in the combo will work more than the 4 others?
Is it easier to acheive the perfect range of power tubes at low volume this way?
Thanks
My Dream Rig Studio:
http://line6.com/sup...your-dream-rig/
My dream rig presets for now 1.9
www.monsieurmaxime.com/resources/Melissiah.zip
www.monsieurmaxime.com/resources/Shine%20on.zip
#2 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5347 posts
  • Registered Products:6
Posted 22 June 2013 - 10:10 AM   Best Answer
  • 1
