ratman24 Posted December 20, 2014 Share Posted December 20, 2014 The mid knob does not work on my amp. If I connect to the Editor on my computer, I can adjust mid EQ settings, so it's a hardware issue, not software. Has anyone dealt with this before? I was going to see if there was a bad solder connection from the pot to the board. I guess I could try replacing the pot as well. Just wondering if anyone has had a similar problem and has any advice. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted December 22, 2014 Share Posted December 22, 2014 Before opening up the amp (I assume its no longer under factory warranty), I'd do a back up of all user patches and then try a factory reset. Quote Link to comment Share on other sites More sharing options...
ratman24 Posted January 1, 2015 Author Share Posted January 1, 2015 Thanks Mike, good tip. Factory reset did not work, but I'm glad i tried first anyway. I believe I just ordered the correct pots to replace. I'm sure if I knew more about electronics, I could test and validate this is the issue, but they are cheap parts, so it's no burden. Will try and remember to update if I find the solution, in case anyone else has the same problem. Quote Link to comment Share on other sites More sharing options...
