stevesavini Posted December 24, 2014 Share Posted December 24, 2014 Newbie. After loading a tone via preset or from cloud, and you then start to tweak it, how do you know what the original settings were for reference? I have other Line6 products, and when you first load a preset the knobs, settings, etc. aren't really used, but as soon as you touch one, the whole sound can change (somtimes quite dramatically) because it starts using your tweak. Typically, there is a light or other indicator when you adjust a setting and match the original setting (for example, as you adjust delay level, you will get an indicator that your setting matches the original preset). But, as I am tweaking the remote app, I don't seem to see any indicator for original settings. If I go too far or make a mistake, how do I get back towards the original settings (other than reloading the preset and starting over)? Quote Link to comment Share on other sites More sharing options...
Triryche Posted December 25, 2014 Share Posted December 25, 2014 Reload the preset.(I know, not the answer you're looking for) Unless you save the changes to the hardware, the preset will not change. Also, you cannot overwrite tones from the cloud. Quote Link to comment Share on other sites More sharing options...
